Old 28th July 2007, 05:45 PM   #1
Send a message via Yahoo to ANTHONY2181
Default Peerless 3 way
Hi there,
I'm wondering if you can help me I'm thinking of getting a pair of Peerless xls 10 830452s to make a pair of speakers.I really like the looks of the spendor s9s or there abouts I already have a pair of Volt LS201s mid bass units and a pair of Vifa XT25TG30-04 tweeters .Could these units work together ?
Best Regards
Anthony
(Ant2005uk1@hotmail.com)
Old 28th July 2007, 06:42 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Anthony,
Within reason, you can make anything work together. Some combinations are better than others. I've built entirely with Peerless before, and entirely with Vifa.
Why not find a completed design that you like that uses your woofer?
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 28th July 2007, 10:49 PM   #3
tinitus is offline tinitus  Europe
Volt LS201, I guess that they have medium high sensitivity ... if so you should find a better woofer, but it may depend how you plan to use your woofer
SPL and Fs on the Volt please, what kind of driver is it really, PA/studio ?
Old 29th July 2007, 12:18 AM   #4
Hi there,
Chris I cant find any info on these units bring used together
on the volt website the LS201 is described as a studio/hi-fi unit. They suggest to use a reflex enclosure.
Here's the spec sheet on the LS201 http://www.voltloudspeakers.co.uk/Lo...ody_ls201.html
I'm thinking of having separate enclosures one for the the MF/HF and one for the LF Peerless unit.
Anthony
Old 29th July 2007, 12:56 AM   #5
Ok, quite normal then
I think the xls are subs only, which means active xo well below 100hz
As woofers with passive xo these two xxls might be better options, but they will need a notch filter
http://www.tymphany.com/datasheet/printview.php?id=26
http://www.tymphany.com/datasheet/printview.php?id=29
Old 29th July 2007, 01:43 AM   #6
Inductor's Avatar
Default Re: Peerless 3 way
Originally posted by ANTHONY2181
Hi there,
...I already have a pair of Volt LS201s mid bass units and a pair of Vifa XT25TG30-04 tweeters .Could these units work together ?
I would do that, 1.st order on the tweeter at 5K and attenuation of 2dB's (4 ohms), the Volt does not need.
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
Peerless SLS 400 4real Multi-Way 12 26th October 2005 05:37 PM
WTB:Peerless bhg41088 Swap Meet 1 6th July 2004 10:41 PM
Whats the difference between the Peerless 831916 and Peerless 850122 SkinnyBoy Multi-Way 9 12th June 2003 03:11 PM
Peerless Vivek Parts 10 23rd June 2001 11:25 AM
Page generated in 0.08208 seconds (74.89% PHP - 25.11% MySQL) with 10 queries
