Old 26th July 2007, 10:40 PM   #1
luvdunhill's Avatar
Default External passive crossovers... In front of the power amplifier?
so, I have decided to locate the crossover for my new speaker outside the box near my amplifier... then I got to thinking, would there be any advantage to locating the crossover between the preamp and amplifier? Maybe located in a tape loop on the preamp? Then I could have multiple crossovers and switch between them?
I guess there could be some impedance matching issues, or something... any ideas?
Old 26th July 2007, 10:42 PM   #2
Did it Himself
richie00boy's Avatar
No that's called a passive line level crossover. Some like them but IMO you might as well make it active and get even more benefits.
You are of course realising that putting something at line level needs one amp channel per drive unit?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th July 2007, 10:42 PM   #3
Passive xover is for use between power amp and loudspeaker.
What you want is the use of active filtering between pre-amp and power amp. So, an entirely different matter!
{Marantz CD-7 Guido Tent Clock ---> HMS Sestetto MKII XLR ---> Electrocompaniet ECI-4 ---> Kimber 8TC ---> Eros MKII DIY}
Old 26th July 2007, 11:37 PM   #4
luvdunhill's Avatar
right, I understand what active filtering is. I guess I was asking about a passive crossover between the preamp and power amplifier, if this was possible or if someone could describe the pros and cons of doing such a thing
Old 26th July 2007, 11:42 PM   #5
theAnonymous1's Avatar
It's called a PLLXO (passive line level crossover).......
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Commercialy made PLLXO's.......
http://www.hlabs.com/technical/crossovers/
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 26th July 2007, 11:49 PM   #6
if I recall Marchand electronics claims they have incredibly good S/N ratio, which, being a passive component, I would have to believe. I haven't looked at his website lately, I'm not sure if he still has them for sale.
JJ
Old 27th July 2007, 12:11 AM   #7
luvdunhill's Avatar
very cool. that's exactly what I was thinking of. Actually, this is a good example of combining the PLLXO and a traditional passive crossover:
http://www.silcom.com/~aludwig/Sysdes/System.gif
so ... I will have to think more about this
Old 27th July 2007, 12:13 AM   #8
luvdunhill's Avatar
JJ
I'm assuming this is what you're referring to?
http://www.marchandelec.com/xm46.html
Old 27th July 2007, 12:58 AM   #9
Yes, that is the one.
Sometime last year(or before) Audio Express (Audio XPress?)had some articles on passive line level crossovers.
Unfortunately, I have no idea what issues those articles were in. I think there were two, but it might have only been one.
JJ
Speaker connectors for use with external crossovers luvdunhill Multi-Way 6 2nd April 2008 12:58 AM
external passive crossover spacejay Multi-Way 4 24th January 2006 10:41 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 09:16 PM
External Crossovers... Mos Fetish Multi-Way 18 16th April 2004 02:18 AM
Passive External Crossover Wiring Duster Multi-Way 2 19th January 2004 10:01 PM
Page generated in 0.10464 seconds (81.73% PHP - 18.27% MySQL) with 10 queries
