Hello.
I guess this is my welcome thread. Anyways. I've built a few speakers, ranging from small bookshelfs, to the cyburg sticks. Now, both were made from MDF. Each time I cam to a point where I realized that they would need a finish. I eventually HAD to paint them, because I cannot veneer anything for my life. Now for my next project, I would like this to be a speaker that will last me quite awhile. I would like to try an open baffle design. Specifically a design that resembles Nomad audio's Ronin speaker. http://www.nomad-audio.com/ronin_1_0c.htm Now I'm really not that great with straight cuts, as I don't have a table saw. So what I'm wondering, is: Will the sub that will be installed provide sufficient bass if the sub is open baffle and not in an enclosure? Thank you. |
#2 |
Depends on how wide the baffle is, 1/4 wavelength is a way of getting an idea. if the baffle was say 9 ft wide it would probably be able to recreate a quality 30-35 hz note easly. 80 hz or 60 hz are probably a better smaller target to aim for. Im sure someone here can explain it much better than me.
#3 |
#4 |
David at audiocircle.com has developed an OB with -3dB at 29Hz.
http://www.audiocircle.com/circles/i...topic=41297.60 |
#5 |
sreten, what kind of drivers were used in those?
That looks very similar to the OB's I want to build (MTM, under 4' tall). I'm still selecting drivers and tooling up, though, so I haven't really built or tested anything yet. |
#6 |
Welcome wafflesomd, that sounds like an interesting project! I would second sreten's suggestion of separate sealed subwoofers if you aren't interested in making your own cabinets. Something like the ones available at PE : http://www.partsexpress.com/webpage....ctGroup_ID=535
Keep us updated on your project! Regards, David |
| Different pre amp idea | bartek | Solid State | 3 | 25th March 2008 03:42 PM |
| I really have no idea what I'm doing here... | d to the g | Multi-Way | 10 | 7th March 2008 06:04 PM |
| P.S idea | noyan | Power Supplies | 15 | 19th December 2007 08:50 PM |
| An idea! Fully balanced TDA1541A DAC idea. Please comment! | cartman | Digital Source | 8 | 17th July 2007 08:18 AM |
| Just an idea | bob123 | Subwoofers | 4 | 9th April 2006 02:28 PM |
| Page generated in 0.08975 seconds (74.42% PHP - 25.58% MySQL) with 10 queries |
