Old 25th July 2007, 11:18 PM   #1
mobyd is offline mobyd  New Zealand
mobyd's Avatar
Default Best way to store speakers
I have a number of vintage speakers (old Tannoy coaxials, WE555s etc) that I want to store for several years until I get time to play with them. Where is the best place to keep them - the attic? the basement? cupboard above the water heater?. Should I wrap then in binliners or leave them open to the breeze?.
Any ideas appreciated (no I don't want to sell them :-)
cheers
M
Old 26th July 2007, 12:06 AM   #2
Inductor's Avatar
I would opt for the living room as for (acoustic) instruments.
Play with them occasionally. Try a humidor...
Old 26th July 2007, 01:43 AM   #3
Geek's Avatar
If there's salt water nearby, a pressurized box. I recently worked on a tube tester that was stored immaculately, but near salt water. Jeebus, the innards were rough!
Inductor's advice is sound. If it's comfortable for you, it will be for the speakers.
Old 26th July 2007, 01:46 AM   #4
OzMikeH is offline OzMikeH  Australia
Perhaps storing them face up for a month then face down for a month too. or edge on, rotating them 90 degrees occasionally, just like good champagne.
Old 26th July 2007, 02:40 AM   #5
Put something under the motor so they're positioned as they would be in a speaker. Rotate 180 degrees every 3 months?
Old 26th July 2007, 02:46 AM   #6
mpmarino's Avatar
You could store them at my house
Seriously, I KILLED a pair of Tannoy drivers by making their environment too dry. The corrugated surrounds crumbled.
Crazy Yankee.
Old 26th July 2007, 02:50 AM   #7
In a dark box I say, away from UV light, which may age the surrounds and anything else with polymers in it.
Lech
Old 26th July 2007, 03:29 AM   #8
ARRAY is offline ARRAY  Canada
ARRAY's Avatar
The best way to store cone based drivers is face down. If the suspension gets in the way, shim up the basket edge to allow for clearance. Store them at room temperature in a dark place with good air circulation and average humidity. Keep them away from UV and second hand smoke. Naturally, they shouldn't be around chemicals either.
If you ever need to store your sub Bakmeel Subwoofers 13 10th March 2009 07:35 PM
Modifying store bought speakers? Y/N? MarkR Multi-Way 11 30th December 2008 03:17 PM
Page generated in 0.09613 seconds (75.06% PHP - 24.94% MySQL) with 10 queries
