Old 25th July 2007, 03:13 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default What is the effect of Baffle Step on the Phase?
Hi all,
Here's a question that just came to my mind.
We all know that the baffle step effect reduces the amplitude of the acoustical for the frequencies below the baffle width.
That can be compensated for, actively or passively.
But if the Baffle Step lowers the signal by 6dB in the lows, how is the phase affected? I haven't seen any information about that.
Alex
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 25th July 2007, 03:22 PM   #2
The behaviour of the baffle-step is minimum-phase. Beacuse of that it has the same phase-response as a so called lead filter. The ususal lag filter that is used to EQ it has a phase and amplitude response that is the mirror image of the lead filter.
Charles
Old 25th July 2007, 03:32 PM   #3
Bricolo's Avatar
Good news.
Is there any non-minimum phase behaviors in "natural" things anyway? (by natural I mean physical effects you can observe, not a filter function created by humans)
Old 25th July 2007, 05:29 PM   #4
sreten is online now sreten  United Kingdom
The phase is affected the inverse of the correcting circuit.
i.e. : BSC puts the theorectical phase back where it should be.
/sreten.
Old 25th July 2007, 05:58 PM   #5
Svante is offline Svante  Sweden
Svante's Avatar
/sreten.
Yes, indeed.
A simulated case can look like this. It can be seen that the baffle step (green curve) has a positive phase shift around 300 Hz, and that the compensation circuit has a negative phase shift of approximately the same magnitude. This results in the red curve, which is near zero.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Baffle step phase respose lndm Multi-Way 21 16th November 2006 11:25 AM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Page generated in 0.06510 seconds (83.08% PHP - 16.92% MySQL) with 10 queries
