I am currently building some new speakers and in the past have only used passive crossovers. Wanted to know what is the difference between an active or electronic crossover vs a passive one. Thanks for helping a new guy.
Cheers |
#2 |
Start here: http://sound.westhost.com/biamp-vs-passive.htm
#3 |
Did it Himself
http://sound.westhost.com look at his articles section it's all explained nicely there.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
Wow didn't take long for a response. Thanks those articles are very useful. I will be using an active xo after reading that information. I'll let you know how it goes. Thanks again.
#5 |
The active c/o articles are very simplistic, for a normal 2-way active is not cost effective unless you use different bass/mid and treble amplifiers. For the bass/mid you can implement active baffle step compensation. For the tweeter you can use its full sensitivity, the higher the better. Still you need to design the c/o properly, not use electronic L/R filters. |
| Active or Passive | bjackson | Multi-Way | 30 | 4th April 2005 10:49 PM |
| Active of passive | audiobomber | Multi-Way | 9 | 31st July 2004 02:31 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| Passive EQ to active EQ | Nuuk | Multi-Way | 13 | 24th May 2004 07:59 AM |
| Passive vs Active I/V | HeadSh0T | Digital Source | 1 | 7th May 2003 10:12 PM |
| Page generated in 0.07119 seconds (72.50% PHP - 27.50% MySQL) with 10 queries |
