Hi guys,
Im just designing the cabinet for my new bookshelf speakers, using Hivi D6.8 and Hivi SD1.1A tweeter, they are actively bi-wired with two gainclones each to give you a bit of background. Now, I have chosen the 2" precision port from PE (should be ariving today) and I'm doing a Cad drawing. Now from what I can see and using WinISD to calculate box dimensions and port length (precison port req. 1" extra to accomodate for the flared ends) Im going to have trouble leaving a 2" gap between the end of the tube and internal speaker wall (or in this case the back of the tweeter; max achievable gap is 1") Without resorting to making the box even deeper, can I place the port facing downlwards as opposed to the conventional? rear mounting. (obviously the cabinet will be on spikes) as this would give me plenty of clearance. I will be using 19mm MDF. thanks for any input Regards Dan |
#2 |
#3 |
Cheers Dude! Will save me from having extra long speakers knowing that.
Regards Dan |
#4 |
There's some formula somewhere about how much area you need under the port to let it breathe correctly. This should help you figure out how high the legs/spikes have to be to prevent chuffing.
Signature: Optional signature you may use to appear at bottom of your signatures. |
| Alpair 6 Bass Reflex Bookshelf | EUVL | Full Range | 61 | 7th October 2010 08:29 AM |
| reducing bass output in a ported bookshelf speaker | Sara | Multi-Way | 1 | 19th October 2007 04:25 AM |
| Safe To Add Another Bass Port? | Thomo | Multi-Way | 4 | 5th May 2007 09:07 AM |
| FE206E in bookshelf cab doing bass? | sumacSK | Full Range | 0 | 12th February 2007 01:45 PM |
| Port position on Bass cab | Gubbe | Instruments and Amps | 1 | 17th February 2006 03:40 PM |
| Page generated in 0.06761 seconds (72.19% PHP - 27.81% MySQL) with 10 queries |
