Old 24th July 2007, 03:59 AM   #1
neutron7's Avatar
Default very small woofer
Does anyone know of a small driver that can go down below 40hz can fit in a small box? i was hoping 6" or less, but will go to 7 if it is impossible (a really tiny one would be even better aesthetically)
They do not have to be efficient .
It is for a mains powered "ghetto blaster" which is really just a powered mp3 player amplifier with a full range driver , and a seperately amplified sub to fill it out per channel and take some of the strain off.
i thought perhaps TB would have something like that, but searching in the PE sub section nothing takes my fancy. i would prefer under $50 each.
best regards N7
Old 24th July 2007, 04:28 AM   #2
chrismercurio's Avatar
Default Well,
The Scan Speak 15W/4531G00 (~$200 each) would do it. The trouble is you want low bass out of a small driver at low cost. If you go to a 7" it will be easier to do for $50-60 (or less) from several vendors.
I would look here:
http://www.zaphaudio.com/6.5test/
Old 24th July 2007, 11:00 AM   #3
el`Ol is offline el`Ol  Germany
Bandor comes into my mind, but it`s not cheap.
http://www.bandor.com
Old 24th July 2007, 01:16 PM   #4
neutron7's Avatar
yes that bandor 100 looks perfect! its a bit too expensive to use for that application though.
what would happen if i got some speakers and lowered their resonance by increasing the cone weight? they only have to go up to about 120hz max.
Old 24th July 2007, 01:36 PM   #5
Default Try this,
http://www.tymphany.com/datasheet/printview.php?id=355
C
Old 24th July 2007, 02:12 PM   #6
badman is offline badman  United States
Custom Title
badman's Avatar
Look over the small tang band subwoofers at www.partsexpress.com, there will be one for you
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 25th July 2007, 04:08 PM   #7
neutron7's Avatar
Default Re: Try this,
C
that one looks perfect! thanks
Old 25th July 2007, 04:27 PM   #8
theAnonymous1's Avatar
What about the Tang Band W5-1138SA 5-1/4" or W6-1139SC 6-1/2"?
I've used the W6-1139SC to replace the blown factory sub in a Camaro. I was surprised with how well it performed.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Woofer choice for small cab PeteMcK Multi-Way 8 12th June 2009 04:48 AM
Small Enclosure Woofer h_andree Multi-Way 5 28th March 2008 09:25 AM
Small Sub Woofer scottjr Subwoofers 8 18th January 2008 04:08 PM
Small 6.5in woofer Praudio Multi-Way 11 14th July 2006 05:23 PM
Very Big Woofer in Very Small Box TroelsM Subwoofers 3 23rd December 2005 01:35 PM
Page generated in 0.08981 seconds (77.15% PHP - 22.85% MySQL) with 10 queries
