Old 22nd July 2007, 04:08 AM   #1
Eton is offline Eton  United States
Default Try counter sinking this one.
What in the world are they thinking about when designing a face plate like this. And what's up with 90 dB?
http://www.madisound.com/catalog/pro...oducts_id=8193
Old 22nd July 2007, 04:21 AM   #2
5th element's Avatar
I think someone posted about this before, and it was said that this unit isnt supposed to be flush mounted.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 22nd July 2007, 04:24 AM   #3
Bare is offline Bare  Canada
Seems Stupid to me,, Simple answer is Don't buy it.
Old 22nd July 2007, 05:36 AM   #4
Geek's Avatar
All you need is a couple of circle templates of the radius used + scroll/jigsaw to make a router jig from 3/8" HDF.
If you're of steady hand, draw the template onto the baffle and freehand a 1/4" straight router bit and ripout the excess with a 1/2" (it can be done!)
Cheers!
Old 22nd July 2007, 08:46 AM   #5
OzMikeH is offline OzMikeH  Australia
the point of the shape is so it can be mounted very close to a mid driver, or even 2 drivers in an MTM configuration. I presume the height and radius is matched to the rims of appropriate fostex drivers.
Old 22nd July 2007, 01:02 PM   #6
zigzagflux's Avatar
Seems like a good idea for MTM, though yes, it might not be installer-friendly.
Old 22nd July 2007, 07:34 PM   #7
I dont have a problem with the shape but it'll be a cold day when I spend $240 for a dome tweeter!
mike
Old 22nd July 2007, 11:14 PM   #8
Send a message via ICQ to TurboFC3S Send a message via AIM to TurboFC3S
A technique similar to this can be used for any irregular shaped driver, I've used it on my Focal TC120TD5's and some Aurum Cantus woofers ...
http://www.exquisiteaudio.com/baffle.html
Old 22nd July 2007, 11:24 PM   #9
Geek's Avatar
Oooo, I didn't notice that
All hail ApexJr tweeters, LOL!
Controlling regulator heat via sinking/shielding hollowman Power Supplies 17 29th October 2008 04:51 PM
diode sinking Lico Chip Amps 6 10th January 2005 04:06 AM
Heat sinking power per frequency ??? Jennice Everything Else 8 16th July 2004 10:58 AM
XSOZ/Complementary Zen heat sinking question needtubes Pass Labs 5 5th April 2004 09:28 PM
BPM counter kinser Digital Source 0 18th January 2004 01:36 PM
Page generated in 0.09439 seconds (73.18% PHP - 26.82% MySQL) with 10 queries
