Old 21st July 2007, 08:38 PM   #1
icanryme2002's Avatar
Question crossover location
i am new to building loudspeakers and i would like to know how and where to mount the crossover and what kind of wire to use to hook them up
Old 22nd July 2007, 07:28 AM   #2
MadMutt is offline MadMutt  Australia
Ill try to answer your Q 1 at a time.
How to mount.
You can 'glue' the xover parts to a piece of mdf/ply/whatever with silicon, epoxy, etc.
You can then either glue or screw this into the cabinet.
Where ?
Well that depends on the speaker your building.
Most mass produced stuff has the xover mounted directly behind the bass driver.
Makes it easier to install/remove.
What kind of wire ?
Whatever you have or can get.
If their cheap speakers anything will do really.
If their ultra exotic, you might want to use something a bit better.
Hope this helps........
Old 23rd July 2007, 03:57 PM   #3
Speakerholic
Cal Weldon's Avatar
Where you mount the XO has a lot to do with how you have built the cabinet and what access you have. It's probably a good idea to keep the coils away from the larger magnets although I'm not sure why.
The size of the wire? 16 ga lamp cord will be fine.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 23rd July 2007, 09:39 PM   #4
Petriej is offline Petriej  United States
Inductors (coils of wire) do their thing because current flow causes a magnetic field. The shape of the inductor and this magnetic field interact to give the desired result.
I think if the magnetic field is changed (too close to a speaker magnet), it may give undesired results.
Signature:
Optional signature you may use to appear at bottom of your signatures.
Old 26th July 2007, 06:50 AM   #5
Default finally
I have been wondering about this for ages.
Now would i mount them up top in a bookshelf loudspeaker by the tweeter to minimise disturbance?
What kind of foam and how much do you put in if the design calls for it?
thx for the response
Old 26th July 2007, 06:50 AM   #6
Lightbulb My CAT only has FIVE livEs
Is braided cat5 usable for the inside of teh speaker or do need something higher gauge?
Make new friends but keep the old. Because one is silver. And the other is gold. (Bender)
Ladies and Gentelmen take my advice pull down your pants and slide on the ice.
Old 26th July 2007, 07:42 AM   #7
I don't think it's going to matter that much were you put the xovers.
If you wanted to be pure/obsesive, you wouldn't even have them in the cabinet at all.
as for cat5, I'd just use std everyday 'twinflex'.
Also known as 'figure 8'.
Old 26th July 2007, 09:14 PM   #8
Question the foamung at the mouth is natural
what kind of foam would i use, do i even need foam?
Old 26th July 2007, 10:07 PM   #9
Pillow stuffing will do.
If you want the best, 100% wool.
Try your local fabric/sewing/quilting/hardware shop.
They should have various types of 'wadding'.
Normally some sort of acrylic fibre.
Only need a small amount.
It's there to absorb any 'back wave' from interfering with the drivers.
Old 27th July 2007, 01:04 AM   #10
so i should put it all along the sides of the cabinet
Port Location ERICSPEEd Multi-Way 4 3rd December 2008 10:50 AM
Crossover location skooter Car Audio 5 3rd January 2008 06:40 PM
reason for crossover mounting location jaygeorge1979 Multi-Way 3 6th February 2006 01:02 PM
BOSOZ R18 & R19 location kennethrl Pass Labs 11 29th November 2005 04:47 PM
Best Location for Passive Crossover EUVL Multi-Way 4 16th February 2005 03:42 PM
Page generated in 0.09906 seconds (78.40% PHP - 21.60% MySQL) with 10 queries
