Old 21st July 2007, 03:11 PM   #1
Ricky is offline Ricky  United Kingdom
Default 18 inch Pro Driver
Hi all.
I have accquired a phenominal driver. It's the Royal Turbomax 900. Here's the TS Parameters for you to hae a look at.
Dia: 370mm. Re: 5.8ohms. Fs:36.60Hz. Qms: 7.84.
Qes:0.47. Qts:0.44. Mms:193.92 (g).
Cms:0.10 (mm/N). Vas: 157.43 Litres. BL: 23.55 (N/A).
L1K: 3.16mH. L10K: 1.16mH. Xmax: +/- 24mm.
Po: 900 watts AES. Sd: 1369cm2. Vd: 6571cm3.
Couldn't believe the Vas when I measured it so did it twice. Came out the same. I'll let you know how I get on with it.
Ricky.
WTB: 2 inch compression driver WithTarragon Swap Meet 0 19th May 2009 02:31 PM
which 10 inch driver in a sealed box qguy Subwoofers 26 9th December 2008 04:55 PM
Focal 4 inch driver. Fs=64. What to do? lineup Multi-Way 10 19th August 2008 10:43 PM
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Best 6 1/2 Inch Driver Under $100 peteboyer Multi-Way 4 26th October 2001 06:57 PM
Page generated in 0.06767 seconds (63.51% PHP - 36.49% MySQL) with 10 queries
