Old 20th July 2007, 01:45 AM   #1
luvdunhill's Avatar
Default 3-way designs with transmission line midrange
hi! I was wondering if there are any documented DIY projects that use a TL mid in conjunction with a sealed or vented woofer? I am new to the TL concept and read in the Loudspeaker Cookbook that using a TL for a mid is something that is beneficial and is not often found in commercial designs. I know the Vandersteen speakers use this approach, and I was just curious if anyone else has done it and perhaps if there were any details on how one might design such a beast.
Thanks!
Old 20th July 2007, 02:16 AM   #2
owdi is offline owdi  United States
owdi's Avatar
I've heard of it being done before, and even saw a project somewhere. It's a neat idea, because you can eliminate the impedance peak that prevents you from using a 1st order highpass filter on the mid.
Dan
Old 20th July 2007, 03:29 AM   #3
I am planning a 3 way and was also thinking of TLing the midrange. Dickason (from memory) recommended a TL if the low/mid xo point was at least 2 octaves from midrange Fs (and sealed otherwise) - or I might have that the wrong way around.
In any case I presume the advantage of TL loading is reducing backwave pressure from a conventional sealed enclosure resulting in a more neutral midrange sound (aka open baffle) - but have the asthetic advantage of a "box" speaker (if you consider that an asthetic advantage).
David.
Old 20th July 2007, 03:55 AM   #4
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
http://www.htguide.com/forum/showthread.php4?t=25932
Maybe not a TL but a damped open back midrange. Supposed to be really good!
Old 20th July 2007, 09:38 AM   #5
Ap is offline Ap
Ap's Avatar
I guess it really depends on how low you want the mid to go, if its crossed at 300hz then there is not much difference to having a large sealed/stuffed box.
For my 3 ways I just used exaclty that, with a non-parallel top/bottom, so the mid chamber reduces in size towards the back of the enclosure (kind of like a TL).
If your mid was crossed first order at 100hz then it maybe beneficial.
Andrew.
Old 20th July 2007, 10:32 AM   #6
DAMIC is offline DAMIC  Seychelles
http://digilander.libero.it/piani/ca...generale-2.jpg
TDL made speakers with T/L mid and woofer, so maybe you will get some idea.
Old 20th July 2007, 04:14 PM   #7
luvdunhill's Avatar
Andrew.
Ap: cool! do you have any plans / pics I could take a peek at?
Also, I'm thinking first-order at around 150 Hz
So in the above case that Jonasz gave, a TL with taper of 1 is used. Are there some formulas or guidance on what different widths and lengths, or geometries will do in the case of a midrange? LDC has some good information for some of the more popular geometries... I wouldn't consider any folded options, maybe the straight, tapered, or the other one listed in LDC and then vary the stuffing of the line for tuning.
Also, are there any indications from the T/S parameters if a mid would work well in these TL shapes?
Old 23rd July 2007, 04:20 PM   #8
luvdunhill's Avatar
also, another question in addition to the above. What do people use to model transmission lines? The formulas given in LDC are really too general, they don't even have tables for a straight line with taper = 1.
Old 23rd July 2007, 11:57 PM   #9
Ap is offline Ap
Ap's Avatar
This is a plan view which gives you a bit of an idea.
Essentially the mid box is non-paralleled stuffed with wool/poly.
Crossover is 300hz 2nd order so the drivers dont do any bass.
As for formulas I built a TL (or tapered quarter wave) sub using the 1/4 length of Fs (tuning) & taper of 1.25 x Sd to 1 x Sd,
there is some good modelling software around which can model response for you.
Andrew.
Old 24th July 2007, 07:38 PM   #10
luvdunhill's Avatar
links?
looks very nice. I'm thinking more of a straight TL with taper = 1, but once I get something to model things, I may find something I like better. I will need a configuration that will load the mid to low frequencies though ...
Transmission Line Help Fradbut Multi-Way 9 9th March 2009 08:03 PM
dealing with modal resonances in midrange transmission lines thadman Multi-Way 15 9th November 2008 04:37 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
how to combine Line array and transmission line together Jared Multi-Way 5 19th April 2004 10:32 PM
Page generated in 0.10431 seconds (85.18% PHP - 14.82% MySQL) with 11 queries
