Old 19th July 2007, 10:28 PM   #1
larksp is offline larksp  United Kingdom
Default first home speaker build
this is the first one i made it is basically the b&w cc6 s2 but will all new parts other than the crossover.
the 2 parts i found harder one being not round speakers for making it flush and the tweeter not have a normal case they do as in can screw from the out side that one done do that..... anyway here it is
Old 19th July 2007, 10:29 PM   #2
and this was the none finnished has more damp in there is braced btw
Old 20th July 2007, 04:14 PM   #3
badman is offline badman  United States
Custom Title
badman's Avatar
looks like you did a nice build, but not really clear what the design is- you took the parts out of the B&W and reboxed them? If you retained the crossover, did you maintain the same baffle orientation (spacing/location between drivers)?
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 20th July 2007, 08:19 PM   #4
thanks for the comment i did not think anyone was going to bother to say anything even if it was bad i would not have minded.
o and covered in a vinyl stuff the black is a wood one and the front like a marble what is easier to see
front was going to be a perpex black 3mm but did not bother in the end
i have a cc6s2 in my home cin system anyway and now build this one.
the test sound by ear was good the same or better seems to come out louder as well,,,, to the b&w one
i got the parts brand new, apart from the crossover what come off ebay used for £6
could have got it new.. spare/replacement from site but that would be £50..
then took the ruff width and size of the box and then made my own......
the speaker holes and others, i more went with an equal spaced out way so basicly it be near the same places that the normal one is.....
then i have 2 rears to make witch have a viva tweeter and a peerless hds mid with port... will be wired up silver as well as silver cross over wire but wont make them just yet as i have few things to do
Old 21st July 2007, 01:14 PM   #5
hi,if you bought the crossover of ebay pre make. chances are its not right for the drivers.you need a properly designed xover.there are free software programs you can download that will help you get there.also using silver wire,but not having a proper xover is not going to help the sound
Old 21st July 2007, 01:27 PM   #6
sorry i was a bit unclear
it is a proper cc6s2 cross over made by B&W perfect for the speakers and sounds better or just good as the cc6s2 i have one already
i ment i could spent £50 got in new but i found one been used and taken out for a cc6s2 but for £6
so every thing is fully b&w cc6s2 other than the port and the box i made if that helps
as on the subject of xovers this is one skill i do need to learn what programs to use and how to read them to put the bits together right now i get some else to do it for me what will cost more than me doing it my self i can solder just need simple enough to tell me what to go where
5.1 home theatre build help!!!! ashokavarthanan Solid State 2 30th December 2007 04:22 PM
Should I build a home subwoofer system with two 15" MTX Black Golds (car subs)? dan50 Subwoofers 1 13th September 2007 02:47 AM
How To Build A Home Sub Box clapster Subwoofers 6 24th January 2007 03:49 PM
Help me build a Home Theater subwoofer rocko1290 Subwoofers 3 1st September 2006 08:53 PM
i want to build a sub for my home theater michelevit Subwoofers 13 20th October 2005 05:03 AM
Page generated in 0.08843 seconds (74.52% PHP - 25.48% MySQL) with 11 queries
