What 104mm flange tweeters do I NEED to hear?
Old 18th July 2007, 09:29 PM   #1
TurboFC3S is offline TurboFC3S  United States
Send a message via ICQ to TurboFC3S Send a message via AIM to TurboFC3S
Default What 104mm flange tweeters do I NEED to hear?
I'm going to try something new. I have a nice pair of cabs built, currently housing a GR A/V3 MTM in the top section, and a pair of M-165x's in the bottom. I've been very impressed with these speakers, but of course anything can be improved. So here's my plan ...
I got some of the new XBL motor GR 5.25" drivers to go in the same cabinet, and want to pair them with the best sounding tweeters available that'll fit the 104.5mm cutout. I currently have some Scan 6600 AirCirc's, Visaton KE25SC, Peerless HDS 810921, and Usher 9950's. I also have some Dayton RS28a I could put into the design. I won't be crossing super low, potentially it could be anywhere from 2000hz to 3500hz. Knowing that, and that it has to fit a 104.5mm cutout, what other tweeters would you think I should hear? The obvious exemption is the Seas Millenium, I've honestly never heard one and would like to, but am wondering if it'll do anything better than the AirCirc? The new Seas Mag Excel tweeter looks interesting too, but I'm not a fan of the drooping top octaves ... still, if somebody says it's a must hear I'd give it a shot.
The purpose of this is simply to learn - compare differences between the tweeters and find out what sound I like best. I'm open to trying anything.
Old 18th July 2007, 10:03 PM   #2
Dave Bullet is offline Dave Bullet  New Zealand
Have you seen Zaph's site? His comments are objective not subjective but he does rate tweeters and has quite a few:
http://www.zaphaudio.com/tweetermishmash
You've already got some great tweeters. You probably don't need to listen anymore, but the Seas 27TDFC and 27TBFC/G are rated well and are cheap.
Another site to check is Mark K's (can't post link - seems to be down at the moment?)
dave.
Old 18th July 2007, 10:13 PM   #3
Sure I've seen both their sites, I'm really looking more for opinions based on what you've actually heard. Most tweeters on the market today can handle the crossover points I have in mind, and I have all the measurement gear/experience I need to make them work in a final design. How they actually sound is all I'm concerned with in this case.
I'm not a fan of the TBFC/G btw, it's a bit strident to my ears. I do have a couple TDFC's though that I could try, but had planned on using them in a system I'm building for my Uncle.
Old 18th July 2007, 11:22 PM   #4
PB2 is offline PB2  United States
PB2's Avatar
Have you heard the SEAS T25CF001?
Note that F3,F4,and F5 are below 70 dB from 1.8 kHz up,
F4 and F5 are far below this figure often -90dB.
F2 does not increase with decreasing frequency indicating good
symmetry in the motor.
F2 does increase with increasing freq, however I notice that none of Zaph's measurements show low F2 above about 3 kHz.
Oh, sorry, just remembered this tweeter is not 104 mm. Curious to hear your impressions if you've heard it.
I offered a few comments here also:
http://www.diyaudio.com/forums/showt...33#post1007633
Pete B.
Old 18th July 2007, 11:59 PM   #5
Pete B.
Oh wow, I just assumed the Millenium and all the other Seas Excel domes were 104mm ... but just checked and they're all 110, bummer. I was thinking about the T25CF-003, the one without ferrofluid, but guess that's out because of the 110mm flange.
Old 19th July 2007, 03:09 AM   #6
PB2's Avatar
The CSD plot for the SEAS T25CF001 is also impressive.
Pete B.
Old 19th July 2007, 06:35 PM   #7
crazyhub is offline crazyhub  France
Top of the Accuton tweeter range, C2-24/6 is 82mmx82mm... C2-25/6 is the same driver but 106mmx106mm front plate. Impressive data!
http://www.clofis.nl/nl/thiel/C24-6.pdf
Oh sorry, you need a circular cut out
crazyhub
Old 19th July 2007, 07:12 PM   #8
Yea, I was thinking about making some sort of adaptor plate so I could mount the Accuton in a round 104mm cutout ... that should be easy enough to do, and I've love to hear what they have to offer.
Old 19th July 2007, 08:13 PM   #9
Never heard this one but Tony Gee ( in holiday) uses it on his "project-x" presently working on the x-over:
http://www.humblehomemadehifi.com/News.html
crazyhub
What 104mm flange tweeters do I NEED to hear?Hide this!Advertise here!
104mm Round Tweeter Replacement juz400 Multi-Way 10 26th June 2011 09:55 PM
Flange schematic amelecsol2000 Instruments and Amps 7 16th March 2008 01:51 AM
Port design flange question TheoM Multi-Way 3 2nd November 2003 08:15 AM
why can I hear a 1uF cap (XO=19K) ??? bbaker6212 Multi-Way 9 3rd October 2002 04:48 AM
Copyright ©1999-2017 diyAudio
