Can you tell a driver model from the front?
Old 17th July 2007, 01:10 AM   #1
macaque is offline macaque  Canada
Question Can you tell a driver model from the front?
May sound like a silly question... but here is the gist:
I am looking for some discontinued Vifa drivers which aren't available anymore at the usual DIY places. A local junk store as some closeout speakers that look like they have Vifa drivers.
I'd rather not bring an Allen key to the store and start pulling drivers out to see the model numbers - there are codes on the front surround of the 6.5" woofers (141C). This would be a seriously good source of drivers - so I may just risk it and buy a pair to see (they cannot be returned - just exchanged for the same item)
Do the codes on the front plastic mounting rings mean anything or are they just plastic part numbers?
Thanks to the experts in advance...
Old 17th July 2007, 07:44 AM   #2
Hyldal is offline Hyldal  Denmark
The number on the surround is just the surround manufactures number, It can not be used to determin what driver it is.
It is also difficult because even if it is a standard Vifa driver, manufactures have there own numbers on it, ....and then it is heavely modified and furter developed and much much better than the standard type.....
Can you tell a driver model from the front?Hide this!Advertise here!
LF driver on side versus front AudioGeek Multi-Way 5 22nd February 2009 12:30 AM
Single Driver Front and Rear Horn johninCR Full Range 17 14th March 2005 02:53 PM
driver recommendations for front horn ? tubenutdave Full Range 10 29th January 2005 09:57 PM
glass in front of driver? davepenney Multi-Way 9 23rd December 2003 11:16 PM
driver placement on front baffle griff Multi-Way 3 5th April 2002 11:51 PM
Copyright ©1999-2017 diyAudio
