Finally came out of the full range section for once, figured this applied to the whole thing
I'm thinking about painting a pair of bare MDF cabinets I'm deciding on picking up...obviously priming them well, using sanding sealer, doing it right. Have any of you with painted MDF cabinets noticed a problem with the color fading after a few years? These aren't going to be in direct sunlight, but it still worries me...should it?
Jim J. |
#2 |
This should not be an issue if the cabinets are not exposed to direct sunlight for prolonged periods.
Over a LONG period, any surface finish may deteriorate, as the film strength weakens over time, but I see no reason why painted mdf shoud be more inclined to do so than any other painted finish.. HTR |
#3 |
Have a look at Shinobiwan's posts.
He's done several 'painted' speakers. Current one he's playing with automotive paint. Ferrari red actually. |
#4 |
If it helps at all; I have a pair of party speakers that have only 2 coats of Acrylic gloss house paint on them, primed with an oil based sealer heavily diluted with mineral turpentine and never sanded back.
They have lived on the back verandha for the last 3 years, some rain some sun and have only just started to blister, so I would say that inside and protedted from direct sun even a cheap paint job should last 10 years. What has started to deteriorate ( not unexpected) is the foam surrounds on the RadioShack/Tandy mid-woofers
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
| NAD 314 problem (fading channels) | Juko | Solid State | 21 | 15th August 2011 09:05 AM |
| Need advice on how to paint/add vinyl laminate to speakers | Neville | Full Range | 5 | 26th January 2007 04:27 PM |
| Paint steel chassis with the "aluminum paint" used on wire fence? | vax9000 | Tubes / Valves | 2 | 23rd July 2006 01:14 AM |
| guitar pickup fading | ThSpeakerDude88 | Instruments and Amps | 4 | 31st January 2006 06:15 PM |
| Best/Easiest spray paint for speakers? | mazeroth | Multi-Way | 34 | 6th June 2005 04:26 PM |
| Page generated in 0.07898 seconds (70.10% PHP - 29.90% MySQL) with 10 queries |
