Old 16th July 2007, 05:40 PM   #1
chrismercurio's Avatar
Default Visaton TI-100
Zaph measured these and will be posting them on his site soon. I just wanted to share what he forwarded to me.
Thanks,
C
Old 16th July 2007, 05:41 PM   #2
Default and
HD
Old 16th July 2007, 08:51 PM   #3
Jay_WJ is offline Jay_WJ  United States
Impressive nonlinear distortion up to 1.5 kHz. But high 3rd order distortion in the upper midrange doesn't look so good. Considering price, I'd choose the TB W4-1337.
Old 16th July 2007, 08:55 PM   #4
bigwill is offline bigwill  United Kingdom
I wonder how these would be as a fullranger with a shelf above 5Khz?
Old 17th July 2007, 09:35 AM   #5
... high 3rd order distortion in the upper midrange doesn't look so good.
Think of it as a feature, and why it can sound so "detailed", and had several rave reviews.
Crossed at 1Khz, there's probably nothing to write home about.
Old 17th July 2007, 11:50 AM   #6
Wait a minute... the distortion appears to stay well below 1% all the up to 5kHz, at which point the 2nd, 3rd and 4th harmonics represent 10kHz, 15kHz and 20kHz respectively.
It could sound great in the right system! I'm not sure about the huge magnet though. It seems a bit overkill.
Lech
Old 17th July 2007, 02:06 PM   #7
Sorry, I must be having a bad day to be so grumpy.
First off, thank you Chris for sharing your personal results with us.
I would rate this driver above the TangBand W4 1337SA in the non-linear distortion department. This is probably the result of a better motor system.
On the other hand, what I was alluding to was that the cone's behaviour between 5-15Khz has prevented it from being a complete all rounder.
Compared to the HD below 1Khz, there is a slight jump up in distortion between 1-3Khz. This is probably related to the stiff cone break amplifying the HD components, and is not unlike some other metal cones like the SEAS Excel series. I have always suspected that drivers with this kind of harmonic distortion profile can sound "detailed", but sometimes "unforgiving"...
Now IIRC, Dennis Murphy said that this driver is great, but is a bit of a pain to work with. It's not god-sent midrange driver that many of us were hoping for. And from the FR measurements, I can see why- it would need a LOT of work to tame those double or triple peaks at 6-10Khz.
Once that's taken care of, I suspect it would make a great midrange driver.
Now if we could somehow mate the W4 1337SA's cone to the Ti100's motor...
Old 17th July 2007, 03:08 PM   #8
Default Well,
I have been very interested in this driver based on tests in German magazines and the fact that it is shielded. Zaph had the following to say about it and I tend to agree:
"Just got done testing the Ti-100's. Not too bad. Excellent midrange non-linear distortion performance, changing to average as frequency goes higher. Relatively sensitive also. The best use for these would probably with a large format tweeter crossed low, around 1600hz maybe. You could cross higher depending on how much that 3rd order HD bothers you."
I am thinking of using these with a BG Neo3PDR or the Visaton KE25SC. It would be cool to use the RAAL 140-15D but I have a new baby and spending 1k on a pair of tweeters is out of the question.
Old 26th July 2007, 03:56 PM   #9
Bother. I've been waiting for Zaph's comments on these. I was really hoping this would sit between W22s and a scan-speak aluminium tweeter in a 'detailed' sounding system.
Anything metal compare favourably to the Ti100 or Tangband? The Tangband is going to be almost twice as expensive as in the US in europe, and only one supplier can get hold of it.
Anyone seen the TI100M? It is mentioned around the place, but not on Visaton's site, e.g. http://www.soundlabsgroup.com.au/p/V-1273-TI100M/Sound. It has a very strange ascending response curve :s
Old 26th July 2007, 06:59 PM   #10
Charliemouse,
The Jordan JX92S likely would be superior to either the Visatron Ti100 or the TB W4-1337SA. The JX92S is a true full range driver with a 45 Hz resonance freq. and a 5 mm Xmax. It will go lower and higher than either the Visatron or TB drivers. Albeit at more cost though. In the UK you can likely get a resonable price for the JX92S.
Jim
Visaton GF 200 lduarte1973 Multi-Way 10 2nd May 2009 02:59 PM
visaton lejaybo Multi-Way 21 2nd February 2009 05:24 PM
Visaton FS Jed Swap Meet 9 17th January 2009 02:27 AM
"Visaton - is it worth?" or... "Share your Visaton experience" mr_push_pull Multi-Way 10 7th August 2004 06:18 PM
Visaton Vox 200 phibes Multi-Way 0 20th May 2004 09:20 AM
Page generated in 0.10744 seconds (78.96% PHP - 21.04% MySQL) with 11 queries
