Will FRD tools import .txt files?
Old 12th July 2007, 11:52 PM   #1
Slanski62 is offline Slanski62  United States
Default Will FRD tools import .txt files?
A few of the drivers I'd like to try (Usher and Dayton) offer frequency and impedence data as a .txt file, rather than a plot. Instead of using a tool like SPLTrace to import the data, will any of the FRD tools import the data in text format? Any help is appreciated.
Steve
Old 13th July 2007, 04:31 AM   #2
EdwardWest is offline EdwardWest  United States
Default an .FRD is a text file....
The .FRD file type is a standard ASCII text file. It just needs to have the proper header and column delimiter. See this webpage for the specifics:
http://www.pvconsultants.com/audio/frdis.htm
You can use a standard text editor (MS Wordpad) to make the necessary changes, save the file and rename it to (whatever).FRD and it should load with no problems.
Hope this helps,
Edward
Old 13th July 2007, 12:26 PM   #3
Edward, thanks a million for your reply. I'm just learning, so this helps my out a lot.
Steve
Will FRD tools import .txt files?Hide this!Advertise here!
stupid question.... import PCB to PDF.. Stefanoo Pass Labs 6 30th March 2007 02:56 PM
The GREAT Microphone Import!! tarnationsauce Group Buys 0 27th June 2006 04:55 PM
Import tax for electronics in France?? sianturi Everything Else 2 21st September 2004 07:36 PM
Import Files Help............. ermes Multi-Way 11 24th August 2004 04:12 PM
