hello everyone,i won't to know if anyone has any idea on differnt speaker units i could use in a wilson watt puppy clone project..all help would be gratefull.
#2 |
#3 |
thanks for those threads,had seen 3 of those,was thinking of going for scan speak 18w/8545 and waiting on email from audio technology about some of there 8152 20 08's.does anybody know the prices of these??should i be sitting down..now the tweeters,i'm not sure on..should i also go the scan speak route??
#4 | |
#5 | |
wow,on second thoughts,maybe not them then,can you point me in another direction..i should of said that my budget is around the £1000 mark,excluding the cabinets.. |
#6 | |
The Dynaudio drivers are going to be tough to come by now, you could get lucky though. That leaves the Scanspeak's. If your wanting to do a documented clone then always stick with the drivers used by the designer. |
#7 |
Keep in mind the Watt/Puppy is now up to version 8 and there have been a few changes along the way (notably different woofers & a larger bass cabinet).
My picks are: midbass would have to be the Scanspeak 18w/8545, tweeter Focal - check E-speakers for the TC120, http://estore.websitepros.com/173675...category=FOCAL As for the woofers thats probably the hardest choice. Hi-Vi D8.8 might be worth a look at, looks like they have made a rubber/plastic surround version. http://www.madisound.com/catalog/pro...oducts_id=8202 or Peerless 830868 which are probably better value. http://www.madisound.com/catalog/pro...oducts_id=1610 As for the cabinet/crossover thats another story! Andrew. |
#8 |
You can also consider AudioTechnology 23I (cheaper than Flex). But still expensive.
The new Wilson Puppy/ Sophia use Scanspeak Alu cone's as woofer. I think it's this one with a different dustcap http://www.tymphany.com/datasheet/printview.php?id=100 And the Revelator 18W/8531 as mid. |
#9 | |
Are Focal drivers available for DIYers again |
#10 | |
thanks andrew for these address's,have just emailed them for the shipping costs |
| Wilson duette driver compliment | Hastur | Multi-Way | 50 | 26th May 2012 06:47 PM |
| Coaxial direct radiator/compression driver units... | 454Casull | Multi-Way | 6 | 10th September 2004 04:39 AM |
| Driver units | babyfame | Multi-Way | 1 | 2nd March 2004 04:32 AM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
| Page generated in 0.10700 seconds (80.14% PHP - 19.86% MySQL) with 10 queries |
