Putting the Science Back into Loudspeakers - Page 48 - diyAudio
Old 18th September 2012, 03:04 AM   #471
Pano is offline Pano  United States
Pano's Avatar
I was reading that with amusement because I did a gig about a week ago in a big, reverberant shed. 100'x100', concrete walls and floor, steel ceiling. Speakers in the center. Wow, it was live!
At one point I was playing a 1000 Hz tone. I stopped it. The sound did not stop! Then about 3 seconds later it died. Wild. You could punch the mute button on the console and nothing would happen for a few seconds - a strange feeling. We were all laughing and taking turns doing it.
Despite that, it was obvious that it was a large, diffuse sound-field, not a small room at all. I'm not sure where the clues lay, but it was obvious. Identifying it as a warehouse blindfolded might have been tough, however.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 18th September 2012, 05:41 AM   #472
Banned
Originally Posted by Elias View Post
Griesinger states that monophonic bass without any ITD undulation results inside the head locatedness in a small room.
I have confirmed this in my room with monophonic bass with monopole speakers and, indeed, the bass is inside your head ! This is not good, not good at all.
- Elias
I don't get in-head localization nor have I heard such reports from others using multisub configurations.
How did your test look like?
Old 18th September 2012, 05:46 AM   #473
Banned
Your basic assumption is wrong.
Who else besides you disagrees? All current papers and solutions about low frequency optimization in acoustically small rooms use multiple subs driven by a summed signal.
Old 18th September 2012, 06:45 AM   #474
I did not really notice in-head localization with the near field subs yesterday. I was playing lots of Massive Attack with meaty bass lines - the bass moved to the localization cues from the front. I must admit though, that I've never heard a room with high quality bass at high SPL, so I don't have that reference.
For my apartment dwelling, nearfield bass is a good compromise. It is hard to get to realistic SPL without being a nuisance, otherwise, and realistic SPL is important for the illusion as a whole. It passed the fiancee test. I showed her how we can turn it up in a 'bass cocoon' but have the bass disappear when you get up. We had a nice post work debrief with our favourite songs
Note that you have to be careful that there isn't any mechanical vibration giving away sub location at higher Hz.
This might not be appropriate for the thread, but an interesting device to try would be a pipe with mid bass drivers on both ends operating up to ~1000 Hz, behind the head. This could be responsible for bass and ITD, with HF HRTF content coming from front on. The result would be a combination of ambio and Watson. Perhaps such a setup has been suggested already.
Old 18th September 2012, 07:42 AM   #475
That's certainly true and I believe a multiple sub system is a big improvement over a single sub system.
However, I think Elias wanted to argue that your basic assumption, that we only hear the steady-state response at low frequencies, is wrong. I believe Blauert's "Spatial Hearing" should be of interest here. However, if I remember correctly, Toole states that below about 80 Hz there is no audible difference (in terms of locatedness) between mono and stereo bass.
(Please correct me if I'm wrong)
Old 18th September 2012, 07:59 AM   #476
Banned
There seem to be three factors involved.
First, in the presence of modal effects found in acoustically small rooms, is it even possible to deliver appropriate spatial cues? Due to modes the level can drastically vary between left and right ear. This is further complicated by how the two sources of a stereo sub setup couple to the modal field. Such conditions make it nearly impossible to deliver spatial cues to the listening position.
Secondly, not everybody agrees that stereo bass even exists. From Toole "Sound reproduction":
Stereo Bass: Little Ado about Even Less
With apologies to William Shakespeare, this issue relates to the fact that for
all the systems described above [i.e. multiple sub configurations] to function fully, the bass must be monophonic
below the subwoofer crossover frequency. Most of the bass in common
program material is highly correlated or monophonic to begin with, and bassmanagement
systems are commonplace, but some have argued that it is
necessary to preserve at least two-channel playback down to some very low
frequency. It is alleged that this is necessary to deliver certain aspects of
spatial effect.
Experimental evidence thus far has not been encouraging to supporters of
this notion (Welti, 2004, and references therein). Audible differences appear to
be near or below the threshold of detection, even when experienced listeners are
exposed to isolated low-frequency sounds. The author has participated in a few
comparisons, carefully set up and supervised by proponents of stereo bass, but
each time the result has been inconclusive. With music and fi lm sound tracks,
differences in “spaciousness” were in the small to nonexistent category, but differences
in “bass” were sometimes obvious, as the interaction of the two woofers
and the room modes changed as they moved in and out of phase. These were
simple frequency-response matters that are rarely compensated for in such
evaluations. Even with contrived stereo signals, spatial differences were diffi cult
to tie down. This is not a mass-market concern. In fact, some of the discussion
revolved around the idea that one may need to undergo some training to hear
the effects.
Another recent investigation concludes that the audible effects benefi ting
from channel separation relate to frequencies above about 80 Hz (Martens et
al., 2004). In their conclusion, the authors identify a “cutoff-frequency boundary
between 50 Hz and 63 Hz,” these being the center frequencies of the octave
bands of noise used as signals. However, when the upper-frequency limits of the
bands are taken into account, the numbers change to about 71 Hz and 89 Hz,
the average of which is 80 Hz. This means, in essence, that it is a “stereo upperbass”
issue, and the surround channels (which typically operate down to 80 Hz)
are already “stereo” and placed at the sides for maximum benefi t. Enough
said."
Thirdly, stereo bass in (music) recordings is the exception and not the norm. So, why go to great lengths and find a solution to a problem that doesn't even exist?
Old 18th September 2012, 08:07 AM   #477
Perhaps subs close to the listening position could do the trick, or perhaps a multiple sub system in which subs could act as either the source or as a cancellation device to minimize modes. But I agree that it is a very difficult problem.
Indeed (that's the quote from Toole I was referring to). Perhaps the frequency to which "stereo bass" can be heard varies considerably between subjects.
Good point. For me, with all factors considered, a multiple sub system is the best compromise.
Old 18th September 2012, 08:14 AM   #478
Banned
It probably could in a one seat solution. But, would that remove the in-head localization Elias had? By the way, we still don't know what his test looked like.
or perhaps a multiple sub system in which subs could act as the source or as a cancellation device to minimize modes. But I agree that it is a very difficult problem.
It looks like a physically unsolvable problem in acoustically small rooms.
Perhaps. We don't know. The only person in these threads that constantly reports different perceptions than the norm is Elias. He can localize tweeters and gets in-head localization with a monopole subwoofer.
Old 30th August 2014, 11:30 AM   #479
Colin is offline Colin  United Kingdom
Reviving an old thread ...
The OP was a link to an article by John Watkinson. Here is a more recent piece published earlier this year which makes the case for greater IT involvement in loudspeaker design. As always, it's a stimulating read which opens up avenues for further reading.
We need to talk about SPEAKERS: Sorry, 'audiophiles', only IT will break the sound barrier ? The Register
Old 30th August 2014, 11:54 AM   #480
For anyone curious about Watkinson's Legend speakers, there are some pics about half-way down this show report
https://sites.google.com/site/vinyli...show/x-fi-2013
The show was 2013 so it looks like the Legend hasn't gone away yet.
OB any science to it? c3conv Multi-Way 14 24th May 2011 05:46 PM
Putting the Simple SE back together - blown PT - Flashing Rectifier cjkpkg Tubelab 13 15th October 2008 01:27 PM
What is the science behind the gap? Paul W Planars & Exotics 2 19th August 2006 04:41 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 05:34 AM
Copyright 1999-2017 diyAudio
