Old 11th July 2007, 03:24 PM   #1
Account Disabled
Default B&w 'dm/4'
Hi Folks
New here.I have an old pair of 'DM/4's i want to get up & running.I have a saggy bass unit on one side that's causing the Coil to rub on the magnet hence distortion..This is actually the third unit to do this...Any ideas?...
I'm also intrested in a pair of theose 'DM/2'S that came out around the same time, transmission type design, any specs or help with those would be mouch appreciated.
Old 14th July 2007, 11:30 PM   #2
v-bro is offline v-bro  Netherlands
v-bro's Avatar
It's commonly caused by rust/oxidation of the pole(plate) or basket, a bent magnet assembly or even a loose magnet, often caused by dropping the speaker. It can also be caused by dust, ironpowder or just a flake of iron, loose coil windings, damaged coil carrier, loose spider and maybe even more pssibilities....
When it is a bent magnet assembly/bent basket you can most of the times determine by pushing on the cone all around, you'll find a spot or area where you can push it to run free...with a bit of luck you can bend it straight again...
I once had repaired a Seas W111 with an oxidation problem from the magnesium basket. The white oxidated magnesium powder had flooded the magnet gap causing terrible scratching ditortion. I carefully 'pulled' the rubber surround loose and did the same with the spider using a sharp flat screwdriver. After cleaning and coating the area behind the spider I glued back the cone and it played wonderfull again...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Page generated in 0.08103 seconds (70.83% PHP - 29.17% MySQL) with 9 queries
