Old 11th July 2007, 07:27 AM   #1
Greg F is offline Greg F  Australia
Default Suggestions for good 6.5' woofer
Hi peoples,
Looking at revamping my home made tower speakers.
Present configuration ...
25 litre vented towers behind lounge chairs in a corner, there just wide enough for the (Jaycar CW2107) 6.5" driver with about 15mm each side spare (this is the side panel), there matched with Vifa D19 tweeter, using (Jaycar) stock cross over @ 3,500Hz 12db.
If and when I ever get my active cross over going it will be used on these speakers.
I've had a look at what's available (In Australia), Extremis 6.8 ($300 pair with freight) or Peerless 830875 ($230 pair)
Have to check if Extremis (86db) will fit width wise but the Peerless should with it's truncated sides + more sensitive @ 88db.
Or any other driver that you may suggest ?
This option would be the cheapest and easiest to pass the finance officer strict guidelines
Or my other interests ...
http://www.rzaudio.com/rz52/mongrel.htm
http://www.theloudspeakerkit.com/sho...&ProcessType=1
These may have trouble passing the guidelines but would give it a go after a bottle or two of red wine
Thks Greg
Sub-woofer amp suggestions hybridfiat Subwoofers 3 29th May 2008 04:25 PM
Woofer suggestions (UK) FullThrottleRic Multi-Way 7 17th August 2006 02:43 PM
Any suggestions for a good solution at a good price? supertronik Everything Else 0 18th December 2005 02:40 PM
Woofer suggestions for MTM anonymoose Multi-Way 6 7th June 2005 08:13 PM
Page generated in 3.12928 seconds (2.00% PHP - 98.00% MySQL) with 10 queries
