Hello Everyone,
I have tried my hand at rebuilding a pair of Infinity Overture 1, powered speakers that I ended up with. I cleaned up the amp boards, replaced some crossover parts and put things back together. The result is that they work but sound really boomy and I'm wondering if it might be due to my (re)construction. I tried to seal all of the drivers and such and I replaced the 1" sheet of sound absorbing material with the loose kind used to stuff pillows. It's pretty stuffed in there. Any ideas? I'm totally new to loudspeaker construction. Thanks, Kurt |
#2 |
Hi, stupid question but have you tried adjusting the boom knob ?
#3 |
There is a "Bass" knob (which should be labeled "Boom") that I have set to its minimum setting and it's still boomy.
#4 |
some crossover parts could be wrong, leaving bass excessive ........ What were they like before you rebuilt them ? |
#5 |
The crossover changes were on one side only and the inductor and the resistor match the schematic and the the good side.
The one speaker that worked beforehand wasn't boomy like they are now. Both sides sound the same which leads me to my construction technique. |
#6 |
Assuming by '1" sheet of sound absorbing material' you mean acoustic fiberglass, then its absorption co-efficient is considerably > polyfil or similar, so try adding more. Also, some OEM speakers I've seen are poorly constructed/lossy by design to 'kill a flock of birds' with one 'bullet', so your sealing them may indeed have increased their 'boominess'.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 |
If you've really stuffed them its possible to overdo it, could cause boom. I suggest playing around with one leaving the other as a control until you find the cause. |
#8 |
I haven't messed with speaker construction before so I'm at a loss on what to even look for. As you suggest, I'll depopulate the stuffing and compare.
Is the idea that the filling (or whatever you call it) is in there loosely? Thanks for you help. Kurt |
#9 |
Typically you stuff based on weight of stuffing Vs volume, i.e. lbs/ft^3, etc.. Maybe this will help: http://web.archive.org/web/200210070...ces/fiberfill/
#10 | |
Speakerholic
| gemini GX-350 Powered Speaker | JDogHerman | Solid State | 4 | 28th January 2008 09:20 PM |
| Reduce the booming bass | hpolkerman | Multi-Way | 22 | 13th October 2007 11:48 AM |
| Booming Horn! | panos29 | Full Range | 12 | 24th December 2004 09:10 AM |
| Best Chip amp for powered PA speaker? | clemon | Chip Amps | 3 | 17th June 2004 04:33 PM |
| battery powered low power speaker amp | fezz | Chip Amps | 10 | 25th October 2003 12:27 PM |
| Page generated in 0.09307 seconds (84.13% PHP - 15.87% MySQL) with 11 queries |
