Old 29th January 2003, 08:56 PM   #1
mkellym is offline mkellym  United States
Default Shiva Help Please !!!
I would like some advise/help on tuning an enclosure I have built for the Shiva MKIII. The box is 6138cu inches/100.584 liters. I am using a 250w plate amp. The driver is mounted verticaly, and the port will be firing downward on to a deflection base. I will be using it mostly for movies, but want it to play music as well as possible, mostly modern jazz/classic rock/country. The room it is in is about 16' x 17' with 10' ceilings, which vault up to about 14'. There is no wall on the opposing wall of the sub. Iam not sure as to use a 3" or 4" port. I understand that if I use a 3" port, I can keep the space between the port outlet and the deflection plate a little closer? If this is true, and the 3" port will work well, then I would prefer to use the 3". My question is what freq. should i tun to (21-22hz?) and then what would be the port dimensions. Thank you for any and all help.
Sincerely,
Matt Kelly
mkellym@aol.com
Old 30th January 2003, 02:15 AM   #2
21" x 4" port would tune to ~20 Hz. 3" is a little small, unless you use a flared port.
Pete
Old 30th January 2003, 01:01 PM   #3
FrankDIY's Avatar
Even 4'' will be probably too small. I always use 4'' and if I drive the sub hard, I hear the port noise.
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 31st January 2003, 10:39 PM   #4
leadbelly's Avatar
Try it with no port first. I have a Tempest + 250W amp. Even in a 12' x 33' room, sealed 165L, downfiring on carpet, I only turn up the gain on the sub amp to 50% to balance my speakers. You can always add a port later.
Old 1st February 2003, 06:54 AM   #5
FrankDIY's Avatar
ported box have a bigger volume so that's not a good idea. Going from ported to sealed is less error prone.
Old 1st February 2003, 07:15 AM   #6
Generally, when a speaker is put into a ported box, the box is considerably larger than when the same speaker goes into a sealed box. The ported speaker will give much more bass in it's new size.
However, this speaker in a 100L box just happens to fit into a range where you can go either ported or sealed. Most subs, you have to decide one way or the other.
The red line is the speaker in a closed box of 100L.
The blue line equals the same speaker with two 3" flared ports tuned to 22 Hz in a 100 L enclosure. The ports are 19 5/8 inches long.
The port flares are available from Parts Express or Madisound. Maybe even Adire-not sure on that one.
Shiva in a big box pkc Subwoofers 2 10th January 2005 10:35 AM
shiva with pr 15 please help!!! hassandaman83 Subwoofers 7 25th November 2004 04:32 PM
Shiva in my car? mazeroth Subwoofers 13 11th November 2004 05:45 AM
Shiva's in the UK seekingwisdom Multi-Way 1 19th April 2004 03:25 PM
Shiva? jmartinson Car Audio 15 16th May 2003 11:41 PM
Page generated in 0.10292 seconds (73.43% PHP - 26.57% MySQL) with 11 queries
