Recommended enclosure for a small Scan-Speak driver (15M4531)
according to Hobby HiFi (German magazine): 15 liters - tuning frequency 38 Hz - BR port diameter 50 mm - length 230 mm. What do I do about the port if I want 2 or even 4 drivers in the enclosure ( 30 & 60 liters respectively)? Will the length stay the same and change the port volume only (2 & 4 times volume) ????? |
#2 | |
or 2 drivers, 30 litres, 1 vent diameter 71 mm length 230 mm. or 4 drivers, 60 litres, 4 vents diameter 50 mm length 230 mm. or 4 drivers, 60 litres, 1 vent diameter 100 mm length 230 mm. |
#3 |
Thanks Svante.
Mingo |
| MTM Port placement between drivers? | tresch | Multi-Way | 4 | 2nd June 2009 12:25 AM |
| Please vote for 2-way monitor drivers/port disposition | Sony | Multi-Way | 7 | 8th July 2008 10:51 AM |
| Port change for Fostex DBR for FE207E | no xo | Full Range | 9 | 19th March 2007 05:16 PM |
| Series-wiring drivers instead of parallel, how does the Xover change? | Glowbug | Multi-Way | 1 | 16th January 2007 04:46 AM |
| Placing the port(s) behind the drivers | cm961 | Multi-Way | 9 | 18th June 2003 04:54 AM |
| Page generated in 0.06373 seconds (72.13% PHP - 27.87% MySQL) with 10 queries |
