#11 | |
/sreten.
#12 |
Hi!
Very easy and good proven speaker is Embla built by Seas. If you search on internet you can find box dimension and crossover schematic. It is a two way built and tested with good result. Now is discontinued that why you have all plans. I built and sounds good. You do not need recalculate crossover. Better go with already done one than with suppose working one. Hope this help you. |
#13 |
if still interested:
I would buy 29TFF/W and 27TBFCG or 27TDFC. Then use 27's chamber with 29 Tweeter. You will get best seas standart textile TW. (I tried this with a friend! and comapred to many seas standart drivers and measured...) you can sell the rest as 27TBF/G or 27TDF. If you still plan 2way system. I would use two 18cm woofers in MTM. If you think of 3way you can try seas CA21rex/DD from madison sale with MB quart mid (also in sale) and some TW (22TAFD for example) already exists a simulated crossover for this: http://img45.imageshack.us/my.php?im...rt22taflp6.jpg |
#14 |
Unfortunately, the SEAS is hard to get here (I need to wait 1month+)
I came up with a project with Dayton drivers. What do you think about this? |
#15 |
the tweeter polarity has to be reversed?
#16 |
This is the simulated response with reversed tweeter:
(tweeter Cs modified to 32uF, 100uF) |
#17 |
See Isis Mk11
http://home.versatel.nl/chiararomee/diy/indexeng.htm |
#18 |
what about the new products? 27TDFNC and R18RNX
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#19 |
nice site, and I didnt know I had it bookmarked allready
#20 |
I meant ER18RNX
| Help on 2way DIY Enclosure | pcyl | Planars & Exotics | 2 | 10th February 2009 12:31 PM |
| Seas 2Way Cabinets | ndc_11 | Multi-Way | 2 | 5th July 2005 02:48 PM |
| Seas L series 6.5" 2way | michael | Multi-Way | 16 | 25th November 2004 05:35 AM |
| Seas 2Way. | Baronty | Multi-Way | 10 | 20th October 2004 07:24 AM |
