Old 5th July 2007, 04:22 PM   #1
nobody special's Avatar
Default Want to go high efficiency... need some horn advice
I would like to build a high efficiency speaker using some PA drivers I have for the bass/mids and some horns for the high mid / treble.
I have no idea what sounds good with horns. I'm also on a budget, so I'm looking for something preferably on the cheap side (doesn't have to be dirt cheap, but not much more than $100 a driver). Looking to handle a range of 1.8K and up. I've been considering using some of the parts express wave guides instead of a horn... hoping to get away from the "honking" sound.
I'm looking to get around 97db efficiency or better.
Let me hear some ideas!
Thanks in advance.
Steve
Nobody
Old 5th July 2007, 05:30 PM   #2
1.8kHz and up should be in the range of 97db/W without a horn.
>=105db/W should be your target for PA horn
I believe the Tannoy pepper pot loaded compression horn in the dual concentric is a basic 125db/W before applying equalisation for the rising response and attenuating the 3kHz peak. And that is designed for domestic duty.
regards Andrew T.
Old 5th July 2007, 07:19 PM   #3
Thanks for the reply...
Yeah, I'm a horn dummy. I know very little about them. When I stated 97db, I was looking at the amplifier power and SPL I wanted to have. I know a horn can belt out >100db, but what mid-bass can keep up with that?
Nobody
Old 5th July 2007, 08:22 PM   #4
Speakerholic
Cal Weldon's Avatar
What are the drivers you are trying to match to?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th July 2007, 09:31 PM   #5
125 dB/W? Is this correct?
Old 6th July 2007, 01:48 AM   #6
Default Re: Want to go high efficiency... need some horn advice
Thanks in advance.
Steve
Altec Lansing or JBL compression driver with exponential horn would be my recommendation. Decent sounding drivers are not cheap though. Some are no longer made but used ones like Altec Lansing 802D or 802-8D drivers are found on ebay. Along with horns like 511B or 811B will provide 105 db efficiency.
Old 6th July 2007, 02:15 AM   #7
Banned
I have no idea what sounds good with horns. I'm also on a budget, \
Steve
Steve,
The way I read this you already have the drivers. What are they?
Old 6th July 2007, 03:14 AM   #8
timbarnes's Avatar
Default Have a look at Wayne Parham's designs
His site is at www.pispeakers.com . He has a number of designs for high efficiency front horns that use PA speakers from Eminence and JBL. Some are two way and might work with the drivers you have.
Wayne is also very generous with his advice and has a bulletin board you can reach from his site - I'm sure he'll give you some useful pointers.
I'm in the process of building his Pi Seven horns - still hacking away on the cabinets, so I can't yet tell you how they sound, but there are lots of reports and discussions of the various designs on his bulletin board.
tim
Old 6th July 2007, 08:56 AM   #9
Default OOPS
I think I meant to type 105db/W for the Tannoy treble horn.
regards Andrew T.
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
High Efficiency, High Power Handling? Bogie Multi-Way 3 2nd July 2005 05:49 AM
High efficiency (HORN) vs Conventional design mbon Multi-Way 13 8th June 2004 11:30 AM
High efficiency 2 way using Eminence Alpha6 + Horn tweeter BlackUnikorn Multi-Way 9 16th April 2004 10:19 PM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
Page generated in 0.09715 seconds (77.45% PHP - 22.55% MySQL) with 10 queries
