Old 5th July 2007, 02:26 PM   #1
Gollum is offline Gollum  Canada
Default Hi-Vi B3N polarity
After searching this entire forum, I just can't find the answer to a very basic question. Guess what, I'm unable to find the polarity of a B3N driver ! I know I can probably use a AA battery and test for the polarity, but I'm afraid to break something...
But I have a clue for you ! There is a red line beside one of the terminal. Am I wrong ot the red terminal is the (+) ?
Thanks for your help !
Dino
Old 5th July 2007, 02:41 PM   #2
Don't be afraid.Use 1.5V battery and there you go.
It's voltage anyway that makes the speaker cones moove.
xxx I should correct my spelling xxx
Old 5th July 2007, 03:09 PM   #3
The red stripe indicates +
Old 5th July 2007, 03:19 PM   #4
owdi is offline owdi  United States
owdi's Avatar
Just use the battery, then mark the polarity yourself. It's the only way to be sure.
1.5v is only a third of a watt, so there's no danger of damaging the speaker.
Dan
Old 5th July 2007, 04:07 PM   #5
Yep, and when you use the battery the red stripe still indicates +
Old 5th July 2007, 05:58 PM   #6
Thank you all. The battery test proves the red mark still indicates (+)... :-)
So you were all in the truth !
Thanks for your help.
Dino
Ess AMT polarity? Help promitheus Planars & Exotics 1 13th July 2007 09:52 PM
SMD Cap Polarity, How to Tell? DreadPirate Parts 3 10th February 2007 12:24 PM
GE 97F cap polarity ??? maynardg Tubes / Valves 0 3rd February 2007 09:20 PM
Polarity on OB sub icebear Subwoofers 3 29th April 2005 08:24 AM
LED polarity guitargully Solid State 4 12th January 2004 04:14 AM
Page generated in 0.08227 seconds (76.91% PHP - 23.09% MySQL) with 10 queries
