Hello everyone, drawing a blank here.....
I am looking at the WR125ST, which is 85.6 dB w/ 1 watt. Since it is a 16-ohm nominal speaker, that is 4 Volts input. How do I determine the dB with 2.83 Volts (0.5 Watts) input? I know there is an equation out there, just can't seem to find it.
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#2 |
Just did a little experiment in Unibox. With 0.5 Watt, the output is at 82 dB, ~3 dB less. What is the equation the relates cutting the wattage in half, reduces dB by 3?
#3 |
Sensitivity should be stated as dB/2.83V independent of impedance. The standard version is 85.6 dB (? 86dB) 8ohm, expect 83dB for 16ohm. |
#4 | |
Speakerholic
The equation is 10X the power = 10 more dB. 2X power and 3 dB is close enough for approximating. |
#5 | |
So if P/Pref=0.5, 10*log10(0.5)=10*0.301=3.01 dB. |
| Mms to Mmd calculations | jaya000 | Multi-Way | 2 | 9th February 2009 07:48 AM |
| driver sensitivity vs system sensitivity | bvan | Full Range | 12 | 5th November 2007 07:57 PM |
| Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? | rhythmdiy | Multi-Way | 5 | 5th November 2007 11:33 AM |
| Need help with calculations please. | Wynand | Solid State | 6 | 27th June 2006 01:00 PM |
| sensitivity calculations | michael | Multi-Way | 15 | 14th December 2003 12:39 PM |
| Page generated in 0.07325 seconds (71.78% PHP - 28.22% MySQL) with 10 queries |
