Old 3rd July 2007, 03:16 PM   #1
Audio Junkie
Zero Cool's Avatar
Default X-max = V.C. Length????
How does one determine the Xmax of a driver?
I have a couple of dead subwoofers that i have removed the cone and V.C from and i am curious what the Xmas is. the MFG of the driver mentioned they had an abundance of xmax but because the drivers are proprietary they cant tell me the specs....so now i am curious.
Wouldn't it just be the length of the V.C. winding???
Zc
Old 3rd July 2007, 03:36 PM   #2
Did it Himself
richie00boy's Avatar
It's the length of the voicecoil that stays in the gap. But that is only part of the story - how linear that travel is, is another matter.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 3rd July 2007, 03:58 PM   #3
Audio Junkie
Zero Cool's Avatar
Ok got it. yes linear another story. I am just curious what "an abundance" of xmax meant to this MFG? these days 2" peak to peak isn't unusual for a 18" driver.
Zc
Old 3rd July 2007, 04:04 PM   #4
oshifis is offline oshifis  Hungary
Hm, dead drivers, secret specs... I wouldn't spend any effort in them unless they were free.
Old 3rd July 2007, 04:17 PM   #5
Warp Engineer
On Holiday
AudioFreak's Avatar
As an approximation for Peak to Peak Xmax,
For overhung voice coils it will be roughly
Xmax = voice coil length - gap length
For underhung voice coils it will be roughly
Xmax = gap length - voice coil length
- Dan
Old 3rd July 2007, 05:23 PM   #6
Svante is offline Svante  Sweden
Svante's Avatar
There are different definitions for xmax. The above would approximately result in the maximum linear peak-to-peak travel of the voice coil. I would say that it is more common to divide this number by 2, to get the one-way peak travel.
Anyway, this means that one has to look careful for how the numbers were obtained when comparing xmax figures between drivers, and in particular between manufacturers.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 3rd July 2007, 05:35 PM   #7
Warp Engineer
On Holiday
AudioFreak's Avatar
Yes, that's why I specified Peak to Peak.
Indeed not all Xmax (generally accepted as linear travel) figures are equal and then just to confuse matters further there is also Xmech (mechanical travel before damage results) which is also sometimes listed in spec sheets.
- Dan
Old 3rd July 2007, 09:22 PM   #8
Luke (Uof Iowa)'s Avatar
Some manufacturers use other measurements such as where BL becomes 70% of at rest or using a DUMAX machine. I think there might be a Klippel tool to measure it as well, but I can't remember one specifically.
Old 5th July 2007, 03:30 PM   #9
Audio Junkie
Zero Cool's Avatar
Ok i measure a 25mm V.C. Winding length. with a top plate of about 8mm. So should i figure 25 / 2 = 12.5mm one way - 8mm plate = 4.5mm xmax? 9mm P-P xmax?? approximately??
I understand that this is not an exact. just a rough guess.
Zc
Old 5th July 2007, 04:13 PM   #10
25mm vc - 8mm gap = 17mm peak to peak or 8.5mm one way
problem.... with TL length AudioGeek Multi-Way 7 20th August 2004 10:48 PM
TL length question theChris Multi-Way 18 5th January 2004 07:45 AM
port length busterno1 Multi-Way 5 27th October 2003 08:05 PM
Page generated in 0.12475 seconds (79.28% PHP - 20.72% MySQL) with 10 queries
