16-18cm woofer for sealed enclosure
Old 1st July 2007, 10:25 PM   #1
tpsorin is offline tpsorin  Romania
Default 16-18cm woofer for sealed enclosure
Hello,
Can anybody recommend me a god driver for sealed enclosure? 16-18cm / ~50Hz F3 in max 25l / <100Euro
Old 2nd July 2007, 02:22 AM   #2
CeramicMan is offline CeramicMan  Australia
Companies like:
www.seas.no
www.visaton.com
www.tymphany.com
www.etongmbh.de
have a range of offerings. Though it might be better to look at what you can actually obtain from distributors first.
Lech
Old 2nd July 2007, 05:11 PM   #3
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
This one will get you pretty close to what you have requested .... low Fs and high Qts .... not many 6" will do that
http://www.monacor.dk/produkter/hoej...-9/vnr/101440/
But personally I would consider this one
http://www.monacor.dk/produkter/hoej...-9/vnr/104250/
The only other I know of is ScSp Revelator in 16ohm version .... Fs=27hz, Qts=0.39 .... but very expencive driver and very low SPL .... and probably no better than the above
Anyhow, you wont get much bass from any single 6" in closed box
But you havent mentioned anything about where, why and how
Old 2nd July 2007, 06:18 PM   #4
Thanks for reply.
I want to use it to complement a 13cm fullrange in a small room (3.5x4.5m);
I want to let fullrange without filter, and cross the woofer at about 100 - 150Hz. So, I'm interested only in low frequency response.
Old 2nd July 2007, 06:52 PM   #5
R.I.P.
Originally posted by tpsorin
Thanks for reply.
~ 4dB more efficient than the 13cm and assuming they are on the same
baffle, a series 1st order c/o at the baffle step frequency is your best bet IMO.
/sreten.
Old 2nd July 2007, 07:52 PM   #6
/sreten.
I am also thinking of 1st order, but why do you recommend 4db more than 13cm?
Old 2nd July 2007, 07:56 PM   #7
Duck-Twacy is offline Duck-Twacy  Netherlands
http://www.ejjordan.co.uk/diy/bass/
http://ldsg.snippets.org/vendors/jordan.php
Is that all there is?
Old 2nd July 2007, 08:06 PM   #8
Virtalahde is offline Virtalahde  Finland
The Monacor SPH176 sure does seem interesting. I've been looking for a 6,5" driver with a light (~13-15 grams) paper cone and a BL of around 8, with sensitivity of around 90dB.
Pretty much the only driver that has interested me is the SS 18w8542. But the SPH176 seems nice and is sure cheap enough to just buy and see for yourself.
Does anyone know of distorsion measurements for Monacors?
Old 2nd July 2007, 08:45 PM   #9
Tpsorin, ..... different mattter then ... it might help further if we knew which 5" fullrange you will use
And why do you ask fore a 6" ... it would be better with an 8 - 10", personally I plan to use a 12" fore the same setup
Old 3rd July 2007, 01:44 AM   #10
Actually, there's no rule saying that sealed boxes should use drivers with a relatively high Qts around 0.4 anyway.
My personal preference is use low Qts drivers, augment the bass electronically if necessary, and enjoy the benefits of reduced boominess and box noise.
Lech
16-18cm woofer for sealed enclosureHide this!Advertise here!
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 04:45 PM
Porting my sealed Enclosure KettermanJ Car Audio 1 7th November 2007 12:45 AM
Jordans in sealed enclosure? billnchristy Full Range 3 19th November 2006 05:23 PM
how big of a sealed box will this woofer need ? zuki Subwoofers 7 2nd May 2006 07:16 AM
sealed woofer box patriz Multi-Way 0 2nd April 2002 10:06 PM
