Old 1st July 2007, 08:43 PM   #1
Default like some opinions on this design
hello all
ive been trying to design a set of TMWWs for me for a little while now and i THINK i might have a handle on it now
since this is going to be my first "my design" build id like to make sure i have all my Is dotted and my Ts crossed so to speak............especially with spending the money that these seem to be turning out to be
driver compliment is <so far > going to be: morel MDT-37 tweeter : Aurum Cantus AC-130MKII doing the mid-bass thing and a pair of Audax HT240G0 10" taking care of the lower end .......these drivers are of course are not "set in stone" if someone has any good ideas
enclosed please find a pic of the X over for these..........
xover frreqs are 2250 and 175..............was designed with speaker workshop
cabs will be a 7.4cube ported at 29hz for the 10" morels <2 per cab> and a .5 <ish> sealed for the AC.........
all opinions suggestions comments and poking fun at are more than welcomed
TIA
scott
Old 3rd July 2007, 12:58 AM   #2
anybody?
thanx again
scott
Old 3rd July 2007, 03:11 AM   #3
Originally posted by scottericsonon
anybody?
thanx again
scott
Sure!
The crossovers: I would've thought that it's more important to get rid of high frequencies from the woofer, and not so important to have a steep high-pass filter for the tweeter, unless your main concern is power handling.
Lech
Old 3rd July 2007, 11:10 AM   #4
tinitus is offline tinitus  Europe
My guess is that you will be low on midrange SPL ... a single 5" with double 10" .... the result may be heavy and boomy bass
Those Audax does look very nice
But the 10" is a strange driver with strange specs ..... 4ohm, high Fs, high Qts, high SPL, low VAS, 7mm Xmax, double magnet .... surely intended fore a very special design
With double 10" in BR, you will need drivers with low Qts
MAYBE, if you used a plateamp on woofers in closed box .... still, I think that Fs=50hz on a 10" is on the high side
But, you could be lucky, who knows
Old 3rd July 2007, 06:43 PM   #5
that audax driver did look neat...strange but neat........
after kicking it around i believe you guys are right
heres another design im working on ............
single Morel MDT-37
double Aurum Cantus AC-130MKII
single Dayton RS270S-8 10"
probably set up as a MID-TWEETER-MID-WOOFER
5.0 cf box for the dayton ported @ 29hz
.142 cube sealed for the pair of ACs
cross over points are 2250 and 175
what do you guys think of this one???
thanx again
scott
Old 3rd July 2007, 06:54 PM   #6
Now its the other way round .... one mid will do .... or else this time you WILL need double woofers
Old 3rd July 2007, 07:06 PM   #7
sreten is online now sreten  United Kingdom
http://www.rjbaudio.com/Audiofiles/FRDtools.html
Try dotting your I's and crossing your T's according to the above.
/sreten.
Old 3rd July 2007, 07:35 PM   #8
And you might consider the AurumCantus AC-130F1 .... looks VERY smooth and easy to control ... I do prefer a nice curved cone fore mids
Old 3rd July 2007, 07:52 PM   #9
ive run the FRD tools untill my head almost hurt lol
i really like the curve on the F1 where do you think would be a good crossover point for it??
scott
Old 3rd July 2007, 09:56 PM   #10
Hard to say .... anywhere between 2-4khz
Well, serious .... its "modern" these days to cross around 2khz, before the driver loose too much dispersion
On the other hand, this puts more stress on the tweeter ..... which I think is very much audible .... and because of the need fore steep slopes maybe only recommendable fore 2ways
With low xo point you get the advantage of a much broader "sweetspot" .... but in my opinion also less precise and defined, in other words a bit diffuse and out of phase .... I reckon its in its nature, but only my personal experiense and I may have been wrong on this matter
With higher xo point you get very precise and welldefined imaging with good "pinpointing" effect.... on the other hand also a VERY "narrow" sweetspot, which means that you only have perfect imaging when listening EXACTLY in the middle .... move just a bit to one side, and its lost .... suits me fine though
Listen to the driver and judge from that .... and dont expect it to be perfect in first try .... my advise will be to work with simple solutions, which also means drivers that are wellbehaved outside their passband
BTW .. this is how my crossover looks like .... I dont think I can get more out of the drivers used .... my next speaker will be much simpler ..... small Jordan(?) fullrange with a 12" woofer
looking for opinions on amp design. armstrom Solid State 1 27th June 2008 08:11 PM
Opinions on this HT-sub design please. ßart West-VL. Subwoofers 19 7th May 2008 02:05 PM
Opinions on this B&C design. Paul Dimaline Multi-Way 25 5th December 2006 05:57 AM
ht design opinions ucla88 Multi-Way 12 4th January 2002 04:58 AM
Page generated in 0.11262 seconds (78.08% PHP - 21.92% MySQL) with 11 queries
