I have 2 cabs that are almost ready to paint. I primered with a latex based primer with about 4-5coats. What type of paint will work well with the primer I used? I'm after satin or gloss black finish.
Thanks, Kev |
#2 |
Finish Paint: Latex Paint will bond to latex or oil primer. Oil finish paint
will bond to the latex or oil primer, but may not always work out so well over the latex due to the higher flexibility of the latex. The above is about house paints. Gloss Black AFAIK uses automotive paints and requires many layers of clear laquer over the base colour. |
#3 |
sreten,thanks for the info
I ended up going with white. I bought the tub refinishing kit that is made of some epoxy type. I sprayed but ended up overspraying The epoxy won't work after 12 hours after the initial mix, I think I have to wait til it dries and sand everything down. $35 and half a day wasted |
| Really OT question about paint | Conrad Hoffman | The Lounge | 14 | 22nd January 2008 08:28 AM |
| Quick question on the PP-C1 amp | athos56 | Tubes / Valves | 13 | 20th October 2007 06:37 PM |
| Quick quick question ! | guitvinny | Pass Labs | 6 | 7th February 2007 04:20 PM |
| Quick Question | Staticjeep | Car Audio | 15 | 8th December 2006 08:13 PM |
| Paint steel chassis with the "aluminum paint" used on wire fence? | vax9000 | Tubes / Valves | 2 | 23rd July 2006 01:14 AM |
| Page generated in 0.06963 seconds (67.52% PHP - 32.48% MySQL) with 10 queries |
