Old 28th June 2007, 11:00 AM   #1
Default Minimum size for open baffle driver?
Is there a minimum recommended size for an open baffle driver? Can a 5.5" driver produce dipole radiation on an open baffle, or is it too small?
Would it be advantageous to select a driver with a neo magnet, which is smaller and more compact, thereby obstructing less of the rear wave?
Thank you.
Old 28th June 2007, 11:12 AM   #2
el`Ol is offline el`Ol  Germany
There is no minimum for a driver in a sufficiently large baffle. For narrow baffles one would choose a large driver to have enough sensitivity left after linearizing the 6dB per octave rolloff.
Old 28th June 2007, 12:06 PM   #3
I have wondered about this too. A lot of smaller drivers (esp with shielded magnets) have very little room for the sound t get through the basket. I suppose this could be good if you don't have a very diffuse surface behind the speaker.
mike
mike - www.keepingsundayspecial.org
Help for driver in open baffle ailouros6 Full Range 10 12th December 2008 02:33 PM
Open Baffle - What's Your Image Size ? Will Planars & Exotics 3 12th May 2006 05:15 AM
open baffle loudspeakers and room size Russell Sit Multi-Way 29 7th July 2004 04:44 AM
Small Size Open Baffle Question Gunawan W Multi-Way 13 31st December 2003 07:55 AM
Page generated in 0.07596 seconds (71.38% PHP - 28.62% MySQL) with 10 queries
