Old 30th June 2007, 11:14 AM   #21
el`Ol is offline el`Ol  Germany
If you don`t want to be disturbed by the rear wave, make the Baffle BIG.
http://www.phy-hp.com/English/Commun...ffle_Plan.html
Old 30th June 2007, 12:40 PM   #22
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
If you donīt want to be disturbed by secondary sound sources from the baffle edge - make the baffle SMALL.
http://www.diyaudio.com/forums/showt...43#post1244143
Rudolf
www.dipolplus.de
Old 30th June 2007, 12:47 PM   #23
Hartono is offline Hartono  Indonesia
LOL
I vote for No baffle and anechoic chamber.
Old 30th June 2007, 01:55 PM   #24
terry j is offline terry j  Australia
I vote for being all confused....
we've gone from big, to small, to none.
Old 30th June 2007, 02:09 PM   #25
I guess big box with small baffle will do just fine.....
Old 1st July 2007, 03:28 AM   #26
Well I think I get what you're saying and there's no "one size fits all" solution.
Limiting the box size is all about tuning the bass response, usually so that the Qtc is around 0.5 to 0.707. If you plan on EQing the response with active filters then that issue becomes less important.
However, using an extremely large box/ infinite baffle is all about optimizing the midrange~treble response, which might be a bit counter-intuitive but hey. IMO one important thing to look out for is Accidental horn loading of the back-wave.
Check out the picture. (5" Visaton mid-bass that I might use) The top half has a wide baffle, which gives a smooth and fast expansion rate, whereas the bottom half is a bit wacky because of the tight fit. If you can imagine it in 3d so the speaker is boxed into a corner, it could have some nasty resonances in the 1~5kHz range. Not only that, but the reflections would also be amplified as they travel back towards the speaker.
Lech
Measured monopole and dipole room responses Elias Multi-Way 581 19th November 2012 04:12 PM
Getting Dipole bass out of a monopole subwoofer Hara Subwoofers 18 14th July 2006 12:55 AM
Dipole vs monopole, balls or not ... ? Jussi Multi-Way 11 4th May 2006 03:38 PM
DBX vs BSS vs 24/96 for Dipole/Monopole combo..... gavinson Multi-Way 0 29th November 2005 12:07 AM
Dipole speaker with monopole rear firing midbass? GuyPanico Multi-Way 4 12th November 2005 02:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
