#11 | |
frugal-phile(tm)
box could be sealed, ported, TL... dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 | |
I believe Linkwitz has also stated the same thing concerning your statements on dipoles versus box loading. His Orions employ PP alignment in a dipole, open baffle. His Orions also employ an intricate divider/EQ network, which boosts the bass considerably to achieve a flat response.
(insert clever anecdote here) |
#13 | |
frugal-phile(tm)
dave
#15 | |
frugal-phile(tm)
dave
#16 | |
Or...maybe not
#17 |
hello planet 10, Just to get this straight.
Diagram C requires double volume? so therefore it isnt isobarik? |
#18 |
holy resurrection!
| Isobaric push-pull with Dayton IB woofer | tinitus | Subwoofers | 8 | 7th December 2010 12:32 AM |
| Push-pull woofer alignment | 3-LockBox | Subwoofers | 0 | 26th June 2007 02:40 PM |
| Push Pull woofer physical alignment | eRiCdWoNg | Subwoofers | 1 | 7th June 2005 09:46 PM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| In push/pull woofer mounting, Why Vas will be half that of single driver? | haggy | Multi-Way | 7 | 10th December 2001 02:29 AM |
| Page generated in 0.09708 seconds (79.41% PHP - 20.59% MySQL) with 11 queries |
