Old 24th June 2007, 11:08 PM   #1
bastek is offline bastek  United States
Default My cones are out of control (100-250Hz dip)
My Seas w15cy001 drivers seem to move almost out of sync with the music and the excursion is longer than it should.
I also measured a -4db dip in the 120-280 region, otherwise is quit flat.
The enclosure is about .3cft or 11-12 L. All walls except baffle are lined with 1/2" acoustic foam. The sound is great, but something is not right.
Old 24th June 2007, 11:49 PM   #2
Sonusthree's Avatar
Sealed enclosure?
Old 25th June 2007, 12:01 AM   #3
I forgot the port is 2"x5" round, tuned at around 55hz.
Push-pull LF driver for up to 250Hz AdamZuf Subwoofers 0 21st April 2009 09:47 AM
Searching for Midrange from 250Hz to 7Khz, >97db/1W RussianE39 Multi-Way 18 19th March 2009 10:15 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 11:37 AM
Better Than Cones/Sex mrfeedback Multi-Way 28 13th May 2004 06:02 PM
Pushed In Cones Bider Multi-Way 11 27th January 2004 06:30 AM
Page generated in 0.07073 seconds (73.30% PHP - 26.70% MySQL) with 11 queries
