What are the reasons for Linkwitz' habitual use of symmetrical driver placement on dipoles? He uses this design in both his Orion and Phoenix designs.
#2 |
What kind of disadvantage do you think is created with symmetrical placement?
Davey. |
#3 |
Higher diffraction effect.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#4 | |
But more importantly, the knee of a dipole is based upon the distance to the edge. Positioning a dipole woofer or midwoofer offset, meaning closer to one edge, alters the dipole effect. I believe that it would not result in a standard 6db slope around the knee. It would be a complicating factor. dlr |
#5 |
So symmetrical positioning for a dipole is where it is at? What is the most desirable shape for the edge, a teardrop (rear edge of plane wing) or a curved shape (complete roundover)? What are the benefits of wider vs narrow baffle other than the obvious (wider=higher efficiency, but less of sidewave absorbed, narrow=lower efficiency, but higher percentage of sidewave absorbed)?
#6 | |
Music and Design dlr |
#7 |
As is usual with most speaker design topics....SL has already addressed this on his website:
http://www.linkwitzlab.com/diffraction.htm Also, I think you'd find Linkwitz recommending symmetrical placement of drivers in non-dipole conventional box systems as well. (If he had any interest in those.) A typical box design measured on-axis will measure a somewhat "smoothed" response when offsetting drivers slightly. However, any off-axis measurements will also show a smoother or less ripply response even when the drivers are symmetrically placed. I know this practice of offsetting drivers is viewed as advantageous by many speaker builders, but it really isn't necessary. In a dipole system the baffle width and shape is important to achieve a nicely shaped polar response (un-corrected) that can be equalized for dipole correction and still maintain an even power response. Trial and error experimentation with baffle shapes is necessary in all cases. Cheers, Davey. |
#8 | |
John k.... Music and Design NaO Dipole Loudspeakers. |
#9 | |||||||
The off-axis smoothing is also not a constantly diminishing phenomenon with increasing angle, for symmetric and non-symmetric. The variation is generally greater with a symmetric placement in the shallower angles. As to necessary, it also depends on ones goal. If, as I always do, a maximum of diffraction control is desired through the use of a felt application and probably when using roundovers, the non-symmetric placement is an absolute necessity if minimization is the goal. This comes from a multitude of measurements of my own. As SL states: Quote:
Even his last statement that is arguable correct is not a dismissal. The same can be said of the absoluteness of many things in audio, transient-perfect designs, importance of on-axis response, active vs. passive, group delay, crossover phase shift and others that are all considered gospel by one group or another. With those and any number of others and leaving out the last word on his page, one could say: Quote:
Dave |
#10 |
Dave,
I'm not sure what your point is. Or are you trying to find some conflicting statements within the vast amount of data on SL's website? You probably will find many items. I've talked to SL privately on a number of occasions and he's mentioned to me that he thinks symmetrical placement of drivers is fine even for conventional systems. That's what he's told me.....you can believe it or not.....or nit-pick his statements and website to death if you like. Cheers, Davey. |
| driver placement | speedie | Multi-Way | 4 | 9th August 2009 04:22 AM |
| BIB DRIVER PLACEMENT n' others | herpaw | Full Range | 18 | 27th December 2006 08:53 AM |
| Dimensions and driver placement | Tai-Pan | Multi-Way | 5 | 16th December 2002 04:49 PM |
| Driver placement | Vivek | Multi-Way | 8 | 12th April 2002 07:58 PM |
| Page generated in 0.13479 seconds (82.60% PHP - 17.40% MySQL) with 10 queries |
