I see TMW and MTM driver arrangements often. Can you use MTW driver arrangements? Would that sound good? If you have a TMW and you sit in-line with the tweeter then would the woofer be too far away from your ears or does that not matter due to woofer non-directivity?
How about a "mickey mouse" arrangement? |
#2 |
Sometimes it's preferable. If the speaker is lower than your ears at your normal listening position then having the midrange driver highest gives you a free time alignment. That is why smaller two-way speakers are often recommended to stand on stands with the tweeter lowest.
#3 |
#4 |
Oh, with the tweeter lowest but still at ear level?
What do you mean by free time alignment? I may go this route but I can't find much info online. |
#5 |
He meant with the M at ear level, making a longer path from the T which helps in the acoustic offset.
#6 |
Hi, No. Mid at ear level gives longer path to tweeter,
#7 |
I found those speakers to which you refer sreten. The manual says to position the high frequency unit at ear level.
#8 | |
Hi, I never said Spendor utilised the "path length" diiferences. To utilise "extra path length" for the tweeter, axis is the midrange. One disavantage of the Spendor approach is overall speaker hieght. |
#9 |
I'm not even sure what a path length difference is exactly!
#10 |
That depends on the speakers, the filter and everything else. Bare in mind that most speakers with a slopping front isn't correctly time aligned for exactly the same reason. You have to have your ear exactly at tweeter level for most of those "time aligned" speakers to work properly, most often I find that the speaker is design too low for that to be possible.
Path length is the difference in distance to each driver measured from your ears. |
| Page generated in 0.08418 seconds (78.35% PHP - 21.65% MySQL) with 10 queries |
