Old 20th June 2007, 08:34 PM   #1
SteveT2 is offline SteveT2  United Kingdom
Default 3 way lute shaped floorstander
I have built two different loudspeaker systems and now have the time and energy to build another! However....... my woodworking/cabinet making skills are very high (he said modestly) but my design skills (maths) is pants.
I have access to a laser cutter and some serious woodworking equipment plus an abundance of ideas but I need someone without the woodworking facilities and expertise but with the mathmatical abilities to design the crossover. Also trying to make sense of the plusses and minuses of the various drivers that are available and the suitability of the different flavours/makes of electronic components would be an advantage, in order that between us we could design and build a reference loudspeaker.
By ignoring profit margins and time constraints it should be possible to produce an absolutely fabulous sounding loudspeaker for about £500 - £600, perhaps a bit more. I will be guided by you.
I have an all Naim audio system driving Dave Berriman floorstanders. Principal listening source is CD.
Sonus Faber 2 way - Lute... mot on/off Multi-Way 0 11th April 2006 05:37 AM
ST shaped tube Original Burnedfingers Tubes / Valves 7 13th June 2005 02:02 AM
Shaped PCBs jonclancy Everything Else 12 4th August 2003 07:28 PM
Sonus Faber "lute"patent rwagter Multi-Way 1 30th May 2003 08:46 AM
cube shaped sub box hunter Multi-Way 6 12th September 2002 05:11 AM
Page generated in 0.06579 seconds (68.70% PHP - 31.30% MySQL) with 10 queries
