Old 20th June 2007, 04:32 AM   #1
Moondog55's Avatar
Question Ribbon tweeters at Jaycar in Australia
I think I should have asked this question here in this forum
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 20th June 2007, 05:56 AM   #2
Andy G is offline Andy G  Australia
Andy G's Avatar
That ribbon will only be safe crossed above about 7k, no good with the M11, you are just strectching the M11's too far, good as they are. 3k, maybe 4k max is best with them.
I used the 80mm faceplate Peerless tweeter in "Blackwood", quite nice !!
Old 20th June 2007, 06:42 AM   #3
Moondog55's Avatar
Thanx Andy, as per you advice last time I think i will stick with the Vifa tweeters.
I can no longer hear those very high notes(if I ever could!!) and I do have to stop aquiring some time
Old 20th June 2007, 07:21 AM   #4
Andy G's Avatar
The D26NC is a far better decision !!! Its a VERY nice tweeter. !!
Old 20th June 2007, 07:28 AM   #5
sandyK is offline sandyK  Australia
Default Ribbon Tweeters at Jaycar
I have a pair put aside for future use.
Just because you can't hear anywhere near 20KHZ anymore, doesn't mean that you can't hear the effects of much wider
bandwidth audio. Extending amplifier bandwidth way past the usual 100KHZ (if you are lucky) means that the higher harmonics are present.(sometimes up to the 8th harmonic)
Recent higher quality audio I.C.s usually have a bandwidth exceeding 10MHZ.This contributes to the ability to not only differentiate between different musical instruments (and female voices) but also hear the "air" between them,and a bigger soundstage. I read a very interesting explanation recently by a well respected British audio designer.
SandyK
Old 20th June 2007, 07:42 AM   #6
Andy G's Avatar
I have actually used a pair. and yes they do give a rather nice top end sense. The problem with them is the darn x-o point. I used them above some old Kef T15's which are 38mm sort of tweeters
Old 20th June 2007, 08:00 AM   #7
There is a very interesting explanation about wide bandwidth audio at the attached link. Post no.10
I hope that Graham doesn't mind me mentioning his explanation!
BTW, his products get some pretty damn good reviews too.
SandyK
http://rockgrotto.proboards39.com/in...3226796&page=1
Old 20th June 2007, 08:22 AM   #8
Moondog55's Avatar
OK I will drive the missus crazy and hide a few away until I get a rainy day with more money in my pocket.
Many thanx for every-ones input, but for the current project i guess I will just follow the recipe I was given and build a set of boring closed boxes.
Old 20th June 2007, 08:25 AM   #9
Andy G's Avatar
Certainly i think I hear a difference between a tweeter that rolls off above 15k and one that doesn't, the T15 was probably rolling off around 12k which is why I added the ribbons. only paid $25 each for them :-). I use low capacitance cables (braided Cat5e) on my main speakers, and again, when I put then in, I could swear there was difference from the heavy gauge stuff I had in before.
But lets not discuss this too much , it can get a bit hectic ;-)))
Old 29th June 2007, 05:18 AM   #10
GeeVee is offline GeeVee  Australia
Hi All.
Saw these tweeters also, and have a pair on hold for me.
I am thinking of using them as replacements in my homebrew TL's., changing the Celestions to these ribbons.
At present, the speaker compliment consists of:
KEF B139 Bass
KEF B110 Mid
KEF T27 High
CELESTION HF 2000 (super high)
The crossover point is 12K.
Would it be better to lower the crossover point, or leave as is?
Sorry to ask simple questions, but my experience with speaker building is limited.
George.
Bargain Jaycar Foster ribbon array with FE207E? OzMikeH Full Range 16 30th March 2008 01:31 AM
Ribbon tweeters at Jaycar Moondog55 Planars & Exotics 5 20th July 2007 08:27 AM
|AU only| Foster 'Ribbon' tweeters (Jaycar) mAJORD Swap Meet 0 20th October 2005 09:55 AM
Jaycar Ribbon Tweeter Jye Multi-Way 2 29th July 2005 02:50 PM
Jaycar Ribbon tweeters Xicarius Multi-Way 3 11th July 2005 10:19 AM
Page generated in 0.10068 seconds (79.56% PHP - 20.44% MySQL) with 10 queries
