Geddes on Waveguides
Old 20th June 2014, 02:28 AM   #7001
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
I hear you Patrick! I'm still riding sewup tires so they handle higher pressure than a tire and tube.
Just keeping the conversation going Earl. Got anything new to add about horns. I see you do what I would say I pioneered with urethane years ago. Do you actually make your own horns, mold the urethane? I used and still use high density 65pcf rigid foam for all the things I have done. If you don't make your own tooling things can get rather expensive fast.
Old 20th June 2014, 02:22 PM   #7002
gedlee is offline gedlee  United States
gedlee's Avatar
Yes, I mold my own horns but the polyurethane is not foam. I make some of my own tools and buy some parts from a tool and die house.
Earl Geddes Gedlee Website
Old 16th August 2014, 12:50 AM   #7003
Studio Au is offline Studio Au  United Kingdom
Is there a golden rule for XO slopes for OSWG / Conical horns?
Old 16th August 2014, 01:30 AM   #7004
badman is offline badman  United States
badman's Avatar
One good method:
You can cross higher, electrically first order, and if you tune it right, it can allow you to use the same cap for protection with about a 3rd order final slope, as well as to provide the constant directivity EQ- but you may still need some impedance compensation etc, and it does demand a robust driver.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 16th August 2014, 10:31 AM   #7005
R.I.P.
Is this assuming the waveguide creates a 2pole roll-off?
regards Andrew T.
Old 16th August 2014, 01:13 PM   #7006
gedlee's Avatar
The short answer is no, there is no golden rule - whatever works. Since the passband of a waveguide is not flat (it falls with frequency) the compensation is really part of the crossover.
Old 16th August 2014, 04:13 PM   #7007
badman's Avatar
It's not really that simple- you've got the highpass power characteristic of the compression driver, which ends at about 2nd order, but then the cutoff of the waveguide on top of that. It winds up being a multi-stage cutoff characteristic unless you really hammer it with the crossover, 3rd is just a rule of thumb for the slope immediately below where you'd typically want to have equal amplitude response (the crossover point but not the electrical crossover point as far as the C.D. is concerned).
I hope that helps, it's just my experience and others may feel otherwise. The behavior of the CD/Waveguide/Horn combo will really define what you have to do, if you had to reduce the low end cutoff of the compensation cap by bypassing it with a resistor, for example, you'd need to tack on another high-pass stage to protect the driver.
Old 16th August 2014, 05:19 PM   #7008
gedlee's Avatar
Originally Posted by badman View Post
The behavior of the CD/Waveguide/Horn combo will really define what you have to do ...
That's really the point, there is no hard and fast rules - too many variables.
Old 25th August 2014, 03:40 PM   #7009
Paul W is offline Paul W  United States
Paul W's Avatar
Hi Earl,
I believe you've stated that the wavefront produced by most compression drivers is not flat.
What are the typical wavefront shapes produced by good quality CDs with circumferential phase plugs?
Thanks,
Paul
Old 25th August 2014, 04:35 PM   #7010
gedlee's Avatar
I don't have much data on this, but the few measurements that have been made show that the wavefront is not flat. Flat, of course, is a relative thing - relative to the wavelengths. So this is really only an issue at the higher frequencies where the HOMs start to appear. And even then we are talking about relatively small variance from flat, maybe 10-20% at most. Flat is the intent and it is mostly achieved, but there are errors in typical devices.
Geddes on WaveguidesHide this!Advertise here!
