Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Multi-Way Conventional loudspeakers with crossovers |
#5771 |
I think that if one excludes the Hawksford proposal that what I am saying is probably true. It is certainly true if the phase is not a factor, but there might be cases where the phase changes could alter the situation.
The stochastic interleave might also be a situation that falls under what I am saying, its not clear. The amplitude response on all axes are changing, its not that one axis does not change while the others do. To me, the issue is: could one electrically change other axes responses whille leaving one stationary. I am not convinced that this is possible and your examples don't prove that it can.
Earl Geddes Gedlee Website |
#5772 |
The more I think about this the more convinced I am that one could never fix the response along one axis and change any other axis without changing the original one - with just electronics. I just do not see how this could happen. Changing one axis has to change all the others as well. Now finding the best compromise for this situation is what making a crossover is all about.
#5773 |
Hi Earl,
Sorry for the mishap yesterday. The system did not allow me to upload the attachment, so I removed the message. Hopefully, it’ll be OK now. I have attached a paper, visualizing my line of thoughts, so perhaps you could refer to the paper while reading the reminder of this post. Figure 1 – Shows the original woofer and tweeter drivers – from manufacturer’s specs. I do not know, if the tweeter’s data was taken with a HP filter. Figure 2 – Reconstructed woofer and tweeter. Phase is generated from SPL via Hilbert-Bode Transform. Please note, that woofer is installed in a sealed box – as indicated by the asymptotic SPL (-12dB/oct), going towards lowest frequencies. Figure 3 – Given the information from the previous posts, I have re-constructed one possible version of Abbey’s crossover. I have no idea if this is correct, and I am only showing one LRC network across tweeter. My understanding is, that there are 3 such networks. This figure also contains minimum-phase response of the whole system. Figure 4 - IR of Abbey and SPL + Phase response. This was obtained from your file Abbey30_ir.txt using SoundEasy software. Please note remarkable similarity in phase response between measured and modelled. All phase transitions are in correct places in both: Figure 3 and Figure 4. Figure 5 - IR of Abbey and SPL + Phase response from HolmImpulse. Setup parameters are shown as well. Please note remarkable similarity in phase response between measured and modelled. All phase transitions are in correct placed in both: Figure 3 and Figure 4. Figure 6 – Pos’s measured tweeter phase response. The goal of this whole exercise was to correctly determine phase response of the Abbey. It should be simple and easy to do. Knowing the phase response of the measurement chain would also help. But all the above may turn out to be just a fantasy (and I would not be surprised if it did). Without your input I am not able to progress any further with this issue. Best Regards, Bohdan |
#5774 |
Ok, I understand the plots, but I don;t understand "Without your input I am not able to progress any further with this issue." You have the phase - its in the Holm data that I posted. I don't understand what is missing.
I will say this however, the DE250 data that you show is for an entirely different waveguide than mine and the data is completely different than mine. Hence any similarity in your reconstruction is likely a pure coincidence or "just a fantasy". (Or the fact that it is a minimum phase system so the phase ends up correct for the same end result no matter how you get there.) I don't know which. I never look at the phase so there is not much that I can add.
#5775 |
Heh, I think Earl never felt that phase was important. With only my school education background, I would have thought the same. But ever since I got into the human interface/interaction of control systems, I felt that phase was a very important factor for the appropriate feel of controls, a pretty involving design effort.
I think it would be interesting to take an Abby, and do a linearized phase version, and listen to the difference.
Hear the real thing! Last edited by soongsc; 23rd March 2013 at 08:22 AM. |
#5776 | |
This would be true if the two drivers were located at the exact same point and had the same polar response at (and around) the crossover point, so that the summation would be on phase everywhere (some coaxial drivers might qualify maybe, or synergy horns). Horbarch-Keele crossover is a special case for WMTMW speakers and takes into account the phase shifts and associated consequence on amplitude summation to control vertical directivity. |
#5777 |
This is the response of the whole system, from the IR Earl posted.
I did reverse polarity to get the first peak positive (and have the phase shifts in the right direction up high). I also applied windowing to the impulse in HOLM, so that the response in the lows looks smoother and shorter than it should. I chose the impulse offset so that the phase response reaches 0° around 10khz. Response above 10khz does not look to be minimum phase anyway (due heavy diaphragm breakups I suppose), so I let the phase alone up there. So here choosing this offset I am basically "hiding" the low pass behavior of the compression driver (as well as amplification and measurement systems), because showing it would not have a lot of interest. Of course any other offset or phase polarity could give a different view of the phase that would be equally "true", so it is just a matter of choosing the one that suits your needs. The one I chose let you see the theoretical behavior one would expect from that speaker (24dB/oct acoustical crossover at 1200Hz), and is easier to analyze, or correct using rephase for example. ![]() Last edited by pos; 23rd March 2013 at 11:15 AM. |
#5778 |
I don't think the Abbey would benefit that much: the (acoustical) crossover point is already quite high in frequency (1200Hz) to get major audible gains, and there is not real crossover point with the sub per se.
#5779 | |
You have to understand that I retain phase in all my calculations (through complex number calculations) - it is critical in crossover design - but I just do not understand what importance the phase of the end result has. No one has ever shown it to be audible.
Earl Geddes Gedlee Website Last edited by gedlee; 23rd March 2013 at 01:15 PM. |
#5780 | |
By the way, you keep saying that the Abbey has a 1200 Hz crossover, but that is not true the way that I define it. The acoustical outputs of the two drivers are equal at about 900 Hz and that's what I call the "crossover frequency". You are basically guessing based on you analysis, but it cannot be correct because the filters are not the slopes that you say they are. The HP is electrically only first order, its definitely not 24 dB/Oct. even acoustically.
New To Site? | Need Help? |
