#501 | |
#502 |
I don't know about your location, but from here a compression driver is only a little more expensive than a good 1" tweeter. But a whole lot more robust.
#503 |
Did everyone see this waveguide article?
I haven't had a chance to digest it, but seems very well thought out. http://sound.westhost.com/articles/w...des1.htm#intro |
#504 |
Very interesting and useful practical info - although a similar idea (but without the computations and stuff) is used by Zaph, which btw does not seem to get a citation (or maybe I missed it).
What i was wondering is whether one can make a similar waveguide but asymmetric, that is, with elliptical or section (the aspect ratio being something like 1:2 ). The reason in my case would be the difficulty to accomodate a circular waveguide on an existing baffle. I guess there will be negative consequences (besides the difficulty of construction), but will it still be usable ?
I don't believe in audio believings. |
#505 | ||
This statement is incorrect (and attributed to me!!). A dome source moves axially NOT radially, and does not produce a spherical wavefront particularly at the higher frequencies. This is clearly pointed out in my book - which was not referenced. (I show this problem in detail in the appendices on my website.) It is of note that a dome does not represent a source for which an "ideal" waveguide can be constructed, however, in theory a compression driver does - the OS. I think that the first part of the statement: "I can conclude that the method outlined can produce a constant directivity device that has lower distortion and better power handling than the original driver alone, and there are no measurable results that would indicate the presence of "horn sound"." is probably true, but the the last part may not be. There is clearly something happening at just under 10 KHz, which I would suspect as being a result of the non-radial wavefront from the dome creating a HOM. This could be found to yield some residual "horn sound". Quote:
#506 | |
So for instance, let's say the driver spacing on your baffle dictated that the waveguide could be no taller than eight inches. In this hypothetical situation, that height and the depth of the waveguide would yield a fixed vertical coverage angle. This gets back to the idea that we don't have a "cutoff frequency", like we do with a horn. For a waveguide the relevant parameter is the "coverage angle." Am I paraphrasing that correctly? |
#507 | |
Patrick (or John actually isn't it) - mostly correct. The concept of "cutoff frequency" and "loading" don't really have a meaning to a waveguide, in a waveguide its all about pattern control and minimizing diffraction. That said, these concepts are quite overblown in horn theory too. Different horn contours only have different loading and cutoff "in theory" because in a real device, its basically only the throat and mouth areas that matter. For a given throat and mouth area virtually any horn contour in a device of finite length will have a "loading" that is within about 1 dB at all frequencies. The need to maintain the contour shape and not the area came from a hureristic argument. I was interseted in how one would make a non-symmetric device. I, like most, had become locked into 'horn" thinking in that it is the area change that matters (Websters Equation). But as I looked arround at all of the "correct" waveguide shapes I noticed that they all had exactly the same boundary shape but NOT the same area change with propagation. Then it dawned on me that - of course! - this is what is different about a waveguide and a horn. In a waveguide its the boundary rate of change that matters (all waveguides have catenoid boundaries) and not, as horn theory says, the area change. This was a epiphany for me - although it seems lost on most that I tell it to. |
#508 |
Earl,
you are one serious player in the world of audio. check out his web site Gedlee and his resume. He has written two books and is working on another. also he has written articles for the journal of audio engineering society. somebody please buy his speaker and post a review. |
#509 | |
there is a austrian company, haigner horns, which makes elliptical wave guides. http://www.theaudioeagle.com/columns/column05.html They use CNC , quit difficult horns to be done. I had some email exchange with the owner. He sweares that his wave guide is much better than the spherical horns. What is your opinion in this regard ? Angelo |
#510 | ||
I will compare my performance data with anyone on the planet. I won't deal in superlatives with no meaning. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| danskercher |
| Page generated in 0.17757 seconds (75.29% PHP - 24.71% MySQL) with 11 queries |
