Geddes on Waveguides - Page 504 - diyAudio
Old 25th December 2010, 05:10 PM   #5031
what do you guys think about this peculiar looking horn
Pyle Pro PH715 1" Bolt-On Constant Directivity Horn | Parts-Express.com
apparently the same horn is used in NEXO PS8 speakers
Old 25th December 2010, 07:05 PM   #5032
Originally Posted by doug20 View Post
Here is an updated picture of the prototype
Looks like kind of like the popular QSC HPR152i waveguide (Which isnt sold any more, that could change too).
Now that's SolidWorks if I've ever seen it.
Old 25th December 2010, 07:18 PM   #5033
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Next week we are going to start this prototype and close a "wish list". Any needs for other (S)EOS or OS waveguides? 20" 18", 10"?
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Old 3rd January 2011, 09:18 AM   #5034
AllenB is offline AllenB  Australia
Is calculating power response something that is beyond the average person?
Say, you have taken half a dozen response plots at varying angles. You now want to average them. Would you average the levels in dB, or convert them to absolute voltages and them average them?
Or would you weight them according to their direction, or perhaps weight them according to their in room environment?
I've looked at some of the formulas and had that sinking feeling.
Old 3rd January 2011, 10:21 AM   #5035
speaker dave's Avatar
Not if you are handy with a spreadsheet.
It is power, so you must average pressure squared. You must then weight it by the area of the sphere that each measurement represents.
If you have SPL curves then you can unlog with an equation like 10 raised to the (SPL/20) to get back to pressure. Square that and weight (multiply)times the spherical area that it best represents.
To make the area weighting easy you can figure out an equal area sampling approach, for example, B&K showed that vertical rings of a sphere with equal
height had equal area.
Finally, for the truly lazy, if you look at Toole you will see that the 60 and 75 degree off-axis curves that he averaged came awfully close to the power response of a lot of systems.
David S.
Old 3rd January 2011, 10:59 AM   #5036
I assume you're not talking about any specific spreadsheet, I'm using a hand calculator to good effect. I'd be happy working on just 1/3 octave samples.
I have horizontal 0, 10, 20, 30, 40 and 50. I could simply conclude that they cover an equal sector size and weight them equally.
I could de-log and square as you suggested and then simply average the six, however I wonder whether I should negatively weight the angles that coincide with the side reflection absorbers that I have in my room.
Old 3rd January 2011, 12:07 PM   #5037
Horizontal slices of equal angle don't represent equal areas.
First, are your vertical and horizontal responses the same? If not then horizontal curves aren't enough. If the horn is circular and horizontal and vertical are the same, then each measurement represents a ring on the sphere (the 20 degree measurement could be a ring from 15 to 25 degrees encircling the 0 degree axis. You will see that each subsequent ring is a greater area and must have more weighting in the power average. You also have nothing to represent the back side of the sphere.
If you delog, etc. and then area weight you can get to a "frontal hemispheric average" more or less. There is a question of sufficient sampling of the sphere, but you are probably okay if the off axis response is well behaved (no big lobes that your are missing).
Note that weighting with regard to sidewall reflections may be appropriate but you are no longer pursuing a power response.
I was assumming Excel, but any spreadsheet would do, as would a hand calculator if you like repetitious crunching. I assumed you had the response curves as data points that could be imported (a matrix of SPL vs. F).
David S.
Old 3rd January 2011, 01:06 PM   #5038
gedlee is offline gedlee  United States
gedlee's Avatar
That will give you a rough estimate (fairly rough actually) if done correctly, such as weighting by the area, etc. but you have to remember that this must be "free field" data. If reflections are present than you are not getting the power response of the source, but of the room. In that case you need to spatially average the data.
Old 3rd January 2011, 09:54 PM   #5039
I was tyrying to do the system, which is definately not the same vertically and horizontally. Now, if I were doing the (symmetrical) horn alone, I could simply imagine the circular wavefront and weight according to the height of a vertical chord which intersects the point between the source and the mic...then square it.
For the whole system I guess I could do a quasi thing, like the attached image.
If you delog, etc.
Once I average should I root then convert back to dB?
I used tape on the floor in front of the speaker, fixed the mic, and rotated the speaker whilst huddling absorbers around to produce a semi anechoic area. I will be ignoring the lower end of the results.
Old 4th January 2011, 02:51 AM   #5040
dantheman's Avatar
Allen, can you gate the measurement? I'm not so sure I like your method. Here's what I do to make gated graphs:
****DanTheMan's blog****: Gating loudspeaker measurements
Your lower end accuracy will be very limited, but you are not after that and I don't think it's very needed.
Good luck,
Dan
My Blog
My Music Recordings
Copyright ©1999-2017 diyAudio
