Geddes on Waveguides - Page 403 - diyAudio
Old 26th February 2010, 02:55 PM   #4021
doug20 is offline doug20  United States
Thanks everyone!
I have a simple task of taking 1/2" wood and routing out holes equal to the measurements on those spreadsheets.
I would love to get the spread sheet broken down to 1/2" chunks so I can match the angles with router bits.
Then glue all the pieces together to make a simples waveguide out of wood.\
Im just trying to get a workable molding. The DDS OS waveguide is very hard to source, Geddes doesnt sell his waveguides alone any more. It would be nice ot source a GOOD OS waveguide.
Old 26th February 2010, 03:39 PM   #4022
gedlee is offline gedlee  United States
gedlee's Avatar
Just to be clear, I did, but I found that there was no value in it for me. I believe that this is why there aren't any on the market right now. It seems like a simple part, and maybe it is if you have a lot of money for tooling, etc. but in small lots its very expensive and people just don't want to pay a price that is interesting to a manufacturer.
Some time ago there was a long thread about making waveguides. The overwhelming postion at that time was that they would be easy to make and that I was just gouging the market. OK, where are they then? That thread was the reason that I stopped selling them. Simply put the waveguide, foam plug and mounting plate are the key to what I make and sell and represent the greatest value-added by far. I am not willing to give this away without due compensation for this value added.
I don't make stand alone waveguides, they are molded into a custom baffle. It is extra work for me to cut them out. I have, and will, sell the baffles with foam plug and mounting plate. Just contact me on the side because I do not advertise this. But be fore warned, they are not cheap.
Old 26th February 2010, 04:59 PM   #4023
badman is offline badman  United States
Custom Title
badman's Avatar
After going through months of effort and lots of resin, cloth, foam, wood, plastic, sandpaper, and filler putties, I can confirm- one-offs are exceedingly obnoxious to do in synthetic materials. My production method wasn't ideal either, however. If I had it to do over, I'd do it in wood rings. The results I'm getting are exceedingly nice, but I'm nearing $150 in materials and a minimum of 40 "pure" work hours (no downtime, that's all spraying, spreading, sanding, cutting time). One can go quick and dirty, I got usable results from a foam mold and a plaster cloth layup, but
After all these months, I'm being a little anal about the result- I want nothing less than complete perfection, as I'm so vested in this.
Next ones I make with wood and a router. In retrospect, that would have been much MUCH easier and cheaper. It'd also be a good excuse to upgrade the router head to a 3hp unit. It's currently a 1.75 porter cable but I'd like a little more oomph for when I'm doing larger-scale router ops.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 27th February 2010, 06:01 AM   #4024
Hi Earl,
Originally Posted by gedlee View Post
I'm not sure if this is sarcasm or what.
Not sarcasm, just curiosity. I do not understand how it could be possible to establish the Thiele-Small parameter values for a given driver without physically handling the device. Paranormal activity is the only explanation that I can come up with.
It would even work for compression drivers if measured on a plane wave tube.
I think we just touched the device.... :-).
Kind regards,
David
www.hornresp.net
Old 27th February 2010, 06:14 AM   #4025
Custom Title
badman's Avatar
I believe by "touched" he means- mechanical attachment of mass or resistance to the diaphragm
Old 27th February 2010, 06:58 AM   #4026
Originally Posted by JoshK View Post
Use JohnK's, catapult's or my spreadsheet.
Hi JoshK,
Could you please post a link to your latest spreadsheet. I currently have a copy of OS WG 2.xls, and when I increase the value of the initial exit angle, the radius of the waveguide throat decreases - it does not stay at the specified value. (I have changed the driver exit angle radians formula from =6*PI()/180 to =C10*PI()/180).
Thanks in anticipation.
Kind regards,
David
www.hornresp.net
Old 27th February 2010, 07:14 AM   #4027
Hi badman,
Thanks for the clarification. I really must learn how to interpret Earl's statements :-).
Kind regards,
David
www.hornresp.net
Old 27th February 2010, 10:31 AM   #4028
john k...'s Avatar
Originally Posted by David McBean View Post
Hi JoshK,
Kind regards,
David
Here is the link to mine: http://www.musicanddesign.com/codes/OS_wave_guide.zip
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 27th February 2010, 12:06 PM   #4029
Do you have any molding that are decent that you would sell?
Old 27th February 2010, 01:25 PM   #4030
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
David, YGM...OSR3
Copyright 1999-2017 diyAudio
