Geddes on Waveguides - Page 388 - diyAudio
Old 12th February 2010, 04:56 PM   #3871
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
As expected Ok I will do sim later
Better is to curve the chanels so that they attach normal to the connecting aperature, but that doesn't change the patent so they are not shown.
Like this one?
Old 12th February 2010, 05:20 PM   #3872
Previously discussed in Jean-Michel's thread, an LP caused by the air cushion between diaphragm and phase plug. Curves without LP - horn without a plug.
Old 12th February 2010, 05:28 PM   #3873
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Yeah, with basic geometri and logic, that would be the way that makes sense
About equal areas, and compression ratios, I suppose
Old 13th February 2010, 10:54 AM   #3874
Modeled Earl's phase plug (maybe requires an improvement) has minor influence on directivity - slightly more linear response.
Old 13th February 2010, 03:05 PM   #3875
That looks wrong. The radial openings of the slot should be largest in the middle (like you have them) and smallest at the outside to have equal areas. You seem to have the middle slot being smaller than the outer slot.
Old 13th February 2010, 10:17 PM   #3876
It wasn't bad because I exceed -10dB at 60 deg with CD. Below drawing is a precise redraw from Earl's patent and 18" OSWG. It took almost two hours on dual core CPU.
Old 14th February 2010, 08:54 AM   #3877
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
If you after some specific details - a single high res simu may take you days on dedicated quad core even
Michael
Old 14th February 2010, 10:19 AM   #3878
SunRa is offline SunRa  Romania
Could you please direct to those papers?
Old 14th February 2010, 11:03 AM   #3879
Phase plug with optimum aperture shapes - Google Patent Search
Old 14th February 2010, 07:09 PM   #3880
mige0's Avatar
First statement on paragraph "prior art" :
Uuups
Statement at 48 :
even for a noob its obvious that this is a requirement - such things can only go for patent in the country of "boundless possibilities"
Oh boy....
Together with the crude drawing zjagaja takes for a blue copy - stopped reading there ...
Michael
Copyright 1999-2017 diyAudio
