Need some guidance with BS circuit
Old 20th June 2007, 12:05 AM   #1
GuyPanico is offline GuyPanico  United States
GuyPanico's Avatar
Default Need some guidance with BS circuit
I created my baffle in The Edge and it gave me the data. Now I just need to know what to do with this information. I guess I need an 8ohm resistor, 3.7mH inductor, and 58uF cap? Then wire it as shown in circuit 1. Also, what value should I use for R1, and how does this effect the circuit and the sound?
Old 20th June 2007, 01:02 AM   #2
ttan98 is offline ttan98  Australia
From the output from the CD/DVD player, and plug into the input of the active filter from the design derived from Edge software that will do the trick.
From the output of the Edge active filter you plug into the input of the CX2310, that will take care of the BS.
The above is a general approach, some tweakings of components may be necessary depending on other factors which I am not aware of. Sorry I cannot design for you.
Old 20th June 2007, 09:43 AM   #3
R.I.P.
Normally you include BS in the bass mid crossover, it is not
compensated independently, try following this methodology :
http://www.rjbaudio.com/Audiofiles/FRDtools.html
/sreten.
Old 20th June 2007, 07:28 PM   #4
owdi is offline owdi  United States
owdi's Avatar
Hello GuyPanico,
You do not need both the inductor and capacitor, the program is showing you two different possibilities. Circuit 1 is typically used in a passive filter, while circuit 2 would be used in an active filter.
To use circuit 1, you enter the Re of the driver in R1. This will be somewhere around 5.5 - 6 ohms for an 8 ohm nominal driver. You will also need a zobel.
To use circuit 2, you enter the input impedance of the amplifier in R1. This will be somewhere around 10,000 - 100,000 ohms.
As sreten has mentioned, normally you do not use a separate BSC circuit. Instead, you integrate it into the midrange filter, and use an LPAD for the tweeter. The only time I've seen seperate BSC filters was for fullrange speakers with no lowpass filters.
If you have never built a speaker before, I highly recommend you copy a project posted somewhere on the internet. I'm into my third design, and my projects still don't measure like they model. It's getting better, but I'm still off by 3db on a regular basis.
Dan
Old 20th June 2007, 10:37 PM   #5
Sonusthree is offline Sonusthree  United Kingdom
Sonusthree's Avatar
Is that really true? I thought that it was mainly down to personal preference and convenience. I know that the choice of this resistor would have an impact on noise but that's as far as my knowledge goes.
Can anyone explain briefly what determines R1? The input impedance of the opamp would already be extremely high and the resistance of the feedback loop is at least 2 x R1. Help!!
Kind regards,
Martin.
Old 20th June 2007, 11:32 PM   #6
GuyPanico's Avatar
Thanks for all the help so far.
I'm still trying to understand how to impliment the circuit. The speakers i'm working with are going to be 2 way, active and biamped. For circuit 2, I would place the 8ohm resistor and 58uF cap on the signal wire going to the active crossover?
1) How do you measure the proper impedance?
2) I'm not very good with diagrams yet, how exactly is the circuit wired?
Thanks everyone for your patience!
Need some guidance with BS circuitHide this!Advertise here!
Have idea but need guidance dreadmann Multi-Way 9 21st April 2007 12:24 PM
Looking For Some Guidance CARTRulz Subwoofers 11 15th May 2006 07:34 AM
little guidance thermonuclear Full Range 4 1st September 2005 11:49 AM
Some Guidance thermonuclear Chip Amps 8 27th August 2005 05:05 PM
A padawan needs guidance here Madmike2 Multi-Way 60 4th May 2005 01:50 AM
