Old 19th June 2007, 09:38 PM   #1
tom1356 is offline tom1356  United States
Default Has anyone sucessfully removed a glued down cone?
I have a pair of damaged Tannoy Monitor Blacks with glued down treated paper surrounds. I would like to remove the cones, repair them, and reinstall them. Any suggestions?
My "cult-like" following is accepting applications.
Old 20th June 2007, 09:45 AM   #2
What sort of damage are we talking about ?
/sreten.
Old 20th June 2007, 01:01 PM   #3
Both frames were bent and the cones have wrinkles in them because of it. I want to remove the cones, true the baskets and replace the repaired cones.
Old 20th June 2007, 03:42 PM   #4
I imagine you can :
a) remove the felt.
b) use a solvent to to lift the suspension edges away from the frame.
c) humidify the cones to make them easier to "de-crease".
but
d) don't you still have the problem of the fixed central suspension ?
making the cones impossible to remove ?
/sreten.
Old 20th June 2007, 05:30 PM   #5
The spiders are held in by three bolts. They are very easy to remove.
What I need to know is how to dissolve the adhesive holding the surround down without further damaging the cones.
Removing old glued chunky components wiredmonkey Solid State 8 22nd July 2009 01:36 AM
Has anyone removed the whizzer cone from a Fostex full range driver?? zygibajt Full Range 7 2nd June 2006 01:29 PM
Line arrays getting glued... mazeroth Multi-Way 9 23rd December 2004 11:05 PM
Are my caps leaking or glued on? Zuma Parts 7 24th September 2003 01:43 AM
Page generated in 0.07923 seconds (72.05% PHP - 27.95% MySQL) with 11 queries
