#341 |
Paul,
Just for the record, my apologies for taking the liberty of carrying your torch into unchartered territory here, I wasn't sure if you're listening into this thread and I thought the subject was appropriate ... |
#342 | |
Is the waveguide at the centre of the mids? It's not clear from the photo's and I'm having trouble guessing from the dimensions. Cheers |
#343 | ||
...no secrets hereQuote:
Paul |
#344 | |
To check this, I just did a small and free software here so I can try and find best curves, and verify how directivity should be dependant or not of frequency. While listening on headphones, just move a dot on the time axis and also move it on the amplitude axis, so that the signal stays centered. As you have 7 dots, you can trace a curve level vs time. If somebody wants to try, would be nice if he gives us his results... |
#345 | |
Some unsorted thoughts on that. 1) I worked in developing speech recognizing systems in the early 90's. Around 20ms has been the processing time frame that was suitable for feature extraction in the system we worked with. Overlapping frames of approx 20ms are often used in that area. 2) In 10ms sound travels around 3.4m 1.5m is the approximate minimum distance of an open baffle dipole speaker to be placed away from a rear wall, to achieve that reflections are not spoiling sonic impression. Timeframes in that range seem to form an "acoustical context" in perception. If early reflections are present in that context, the image of original sounds is blurred from distortion to coloration to change in the perception of the "sound event space" (Schallerignisraum) in order of the time delay of the reflections. The VER Range <5ms is related to the design of the loudspeakers structure (enclosure) itself: - Reflecting surface structures - Sharp edges causing diffraction, - Internal cabinet reflections which find their way outside and so on. Interestingly to a certain extent a loudspeaker can be judged by its look, if such flaws are to be expected. Then comes the time range where the loudspeaker has to deal with the next boundaries in the room. E.g. a flat speaker directly in front of wall may simulate in wall mounting. There are only 2 possibilities to keep reflections out of the 10 ms range: 1. Directivity (as constant as possible) of the speaker or 2. Keeping distance to the walls. Strategy 1 leads to a speaker which is less room dependent. A less room dependent speaker is the better speaker, especially if a minimum distance cannot be kept. An open baffle dipole is a combination of both strategies, while demanding distance to the rear wall it is relatively benign to the sides. The diffuse radiation of DML may add a new or supporting strategy, in making early reflections less pronounced, since it is the transient character in reflections which seem to blurr imaging, especially in small rooms or at low distances to the surrounding walls. Interference in more stationary sound seem to cause coloration which can also be minimized by directivity and diffusivity. They are no mutually exclusive strategies. When comparing the concert hall sound field with that of the small home listening room we have a major problem: We want an image of the (high quality) sound field of the concert hall (or virtual sound event space) to be placed in the acoustical small room. If the job where the other way round, the task would be much easier ... The quality of the speaker-room system has to pimped in terms of - suppression of early reflection - modal density - diffusivity Since the job is impossible enough, one cannot afford to leave out one of these dimensions IMO. Kind Regards Last edited by LineArray; 26th February 2010 at 10:42 AM. |
#346 |
instead of "modal density" i should have written "balanced modal excitation below schroeder frequency" because the modal density of a given small room cannot be changed. Kind Regards |
#347 |
That's probably the wrong term.
Schallereignis = sound event = physical properties of the sound field Hoerereignis = auditory event = subjective sound perception of sound I guess you wanted to talk about spatial attributes of auditory events? 3. Flush-mount speaker into a wall. |
#348 | |
listening room reflections. The image formed by auditive perception contains an estimation of the properties of the "sound event space" (Schallereignisraum) e.g. a concert hall where a live recordig had taken place, with its unique reverberation characteristics. That perceptive image of the "sound event space" may also be changed by listening room reflections, not the "sound event space" itself. Kind Regards |
#349 |
well, this is quite fundamental disagreement, with immense impact on practical speaker design principles, isn't it?
"high phooey and hystereo" - Yascha Heifetz |
| QuAD ESL 57 in a small room? | dude007 | Planars & Exotics | 3 | 26th November 2007 02:22 PM |
| Suggestions for a small room? | StoneT | Full Range | 4 | 25th October 2007 02:08 AM |
| Big Room to Small Room | CARTRulz | Subwoofers | 1 | 21st August 2006 05:59 AM |
| Small Monitors, Small Room | Seth Smith | Multi-Way | 0 | 30th January 2006 05:01 AM |
| Small Room | RAYSIMMONS | Multi-Way | 14 | 6th February 2003 05:06 PM |
